RobsterUK 23 Posted March 20, 2019 Posted March 20, 2019 I have updated to latest server version this evening. Installed on Xpenology server, version 4.0.3.0-1. Emby for WMC version 3.0.307.0. I have 3 users accounts setup, and have age filters applied to each account. I cannot risk having my main user account without a pin. In the server settings for user I have 'Enable in-network sign in with my easy PIN' code tick box checked. If I reset the PIN I can log in without entering a PIN. If I change the PIN, have tried a 4-digit PIN which was previous format & a 6-digit PIN. Neither worked. I can log in by entering the password for the account. But this is not practical with a Logitech Harmony remote. As soon as I reset the PIN, I can gain access. So the settings are getting applied server side. I have attached the latest log from %programdata%\MediaBrowser-Classic\Logs MBClassic-2032019dce80f94cfcb4b2f9caa451d20381a63.log
ebr 16331 Posted March 20, 2019 Posted March 20, 2019 If you are using the 4.0 server, you are going to need to use the Beta of EMC (currently version 3.0.317). Please try installing that and let us know how it goes. Thanks. 1
RobsterUK 23 Posted March 20, 2019 Author Posted March 20, 2019 OK, thanks EBR, ill try it out and report back.
Solution RobsterUK 23 Posted March 20, 2019 Author Solution Posted March 20, 2019 If you are using the 4.0 server, you are going to need to use the Beta of EMC (currently version 3.0.317). Please try installing that and let us know how it goes. Thanks. Installed the Beta and PIN is functioning as before. Thanks. 1
fonte 0 Posted September 9, 2020 Posted September 9, 2020 en los ajuste del emby puedes camiar el pin Acceso red loca @cayars
Carlo 4561 Posted September 10, 2020 Posted September 10, 2020 12 hours ago, fonte said: In the emby settings you can change the Local Network Access pin @cayars Hello source, What exactly are you asking? Is it the 4 digit code you can login with instead of typing a password on your local network? If so that is under the USERS menu, Password tab at the bottom (after a password has been assigned).
