wmd45 0 Posted March 19, 2019 Posted March 19, 2019 I have Live TV configured using an HD Homerun Prime and I have two listings of every channel with one channel being blank. Just the channel number with no information or ability to tune. I also attempted to use the NextPVR plugin but it doesn't work. I installed the plugin and nothing seems to happen. I also tried to use my Schedules Direct account and again nothing happens. All I get is limited information guide full of duplicated channels.
Luke 42217 Posted March 20, 2019 Posted March 20, 2019 Hi, sounds like one set of channels is coming from Emby and the other from Next PVR. Please try uninstalling the next pvr plugin, and then restart Emby Server. Please let us know if this helps .Thanks.
wmd45 0 Posted March 20, 2019 Author Posted March 20, 2019 OK what I really want to do is use NextPVR so I removed the HD Homerun tuner and left the NextPVR plugin installed and restarted the Emby server but I still have the same issue with duplicate channels. Thank you for your help though.
Luke 42217 Posted March 20, 2019 Posted March 20, 2019 You'll need to refresh the guide in Emby Server, but i would strongly suggest using the native features for a better experience. thanks.
wmd45 0 Posted March 20, 2019 Author Posted March 20, 2019 I think you are right I'm going to ditch the NextPVR and go with Emby native features working directly off the HD Homerun tuner. Seems to be much better. Thank you again.
