davedick 19 Posted March 19, 2019 Posted March 19, 2019 Hello, I'm currently using the Emby built in channel guide and noticed that the Season, Episode data, does not match what TVDB shows. The show I was looking at is Forensic Files. In the channel guide it shows Episode S7:E33 - PaintBall. When I look at TVDB, it says S8 E3. Another one in the guide is S8:E14 - Nailed. TVDB has it as S8 E24. When I look at IMDB, it shows the same as what TV DB (I know there are some shows where the season info is different between the two). Another one - Deadly Curve - Guide shows S9 E23. TV DB shows S8 E40. Is there another site that matches the guide, besides TV DB or IMDB or should it be matching one of these (if so which one) ? Overall I'm trying to see why there is a difference in this particular show Thanks
PenkethBoy 2068 Posted March 19, 2019 Posted March 19, 2019 That data is coming from your EPG provider - not TVDb etc for livetv
davedick 19 Posted March 19, 2019 Author Posted March 19, 2019 "My EPG" provider is the one Emby provides are part of the 4.0 update. I understand that it doesn't come from TV DB, but usually the Season # and Episode # usually matches the DB website. That data is coming from your EPG provider - not TVDb etc for livetv
Luke 42217 Posted March 19, 2019 Posted March 19, 2019 Hi, we'll report this to our upstream provider. thanks.
