RAYZZZ 0 Posted March 18, 2019 Posted March 18, 2019 I put my pin in and I dont get email. I put in server details and it does not work?
ebr 16338 Posted March 19, 2019 Posted March 19, 2019 Hi. Exactly what are you doing and what is happening? There is no email in the PIN sign-in process.
RAYZZZ 0 Posted March 19, 2019 Author Posted March 19, 2019 Hi, when I try to get emby running it says to go to http://emby.media/pin and enter pin but when I go back nothing happens. It says I can skip and enter up address but that doesn't work either, I'm not good with tech so I don't know how to fix! Thanks Ray
ebr 16338 Posted March 19, 2019 Posted March 19, 2019 Hi. Where is your server installed? You know its proper address?
RAYZZZ 0 Posted March 19, 2019 Author Posted March 19, 2019 I have a android tv. My server is on wifi broadband. I'm not sure where server is but I know the IP address. I'm no good with tech stuff, is there another way to find server or connect? Thanks
RAYZZZ 0 Posted March 19, 2019 Author Posted March 19, 2019 I'm not sure. I think my IP address works on other apps. I'm confused what my server is. Is it my IP address? I know my IP address is correct but it does say can't connect to server so I'm not sure what I'm doing!
ebr 16338 Posted March 19, 2019 Posted March 19, 2019 You need to have either installed a server or been invited to connect to someone else's. Please see: Quick start
