KarlDag 25 Posted March 18, 2019 Posted March 18, 2019 (edited) I've been using HW acceleration on my i5-7500 for a while without issues.Recently I added an RX570, and Emby detects (or shows?) quick sync as part of the AMD's possibilities. Not sure if it's an UI issue or a detection issue. Screenshots included.Also, I see decoders detected but no encoders... I know for a fact my kany Lake cpu supports h264 and h265 encoding, possibly more, and the GPU probably does too...Ideas? Bug? Thanks @@softworkz Log.txt Edited March 18, 2019 by KarlDag
Luke 42217 Posted March 18, 2019 Posted March 18, 2019 Hi there, please attach the emby server log as well. thanks.
softworkz 5130 Posted March 18, 2019 Posted March 18, 2019 @@KarlDag - This is a known problem in the current release. It is already fixed in the beta channel and will be fixed in the next release. If you want to stick to release, simply don't select those "invalid" entries.
KarlDag 25 Posted March 19, 2019 Author Posted March 19, 2019 @@KarlDag - This is a known problem in the current release. It is already fixed in the beta channel and will be fixed in the next release. If you want to stick to release, simply don't select those "invalid" entries. Great, thanks. It seems to be working well anyways for me so I won't change anything and it'll be fixed next update. Thank you, you guys are amazing.
