BillOatman 597 Posted March 17, 2019 Posted March 17, 2019 My shield had been sitting idle long enough at the emby main page to go into its screensaver. I ran my application that changes the media to play a livetv channel on the shield. I expected to see the shield wake up and display the live tv channel. What happened instead was I could hear the live tv channels audio but the shield was still displaying the screen saver. When I woke up the shield with the remote the audio was still playing. Selecting a live tv channel played the video correctly, but both channels audio. I went in and out of emby and could not get the original channels audio to turn off. Even at the shield main menu, the audio was still playing. The only way I found to get rid of that audio was to reboot the shield.
ebr 16338 Posted March 19, 2019 Posted March 19, 2019 Hi. What application was handling the remote control?
BillOatman 597 Posted March 19, 2019 Author Posted March 19, 2019 Hi. One that I am developing. The logic is: Standard API authentication and get sessionID of the client device (I can provide that code if desired) // Send info message to the user that the channel is changing MessageCommand mc = new MessageCommand(); mc.TimeoutMs = 5000; mc.Header = "Channel Change Reminder for " + clientUserName; mc.Text = "Channel will change to " + newChannel + " within " + (mc.TimeoutMs/1000).ToString() + " seconds."; await client.SendMessageCommandAsync(sessionID, mc); System.Threading.Thread.Sleep((int)mc.TimeoutMs); // Locate the channel LiveTvChannelQuery ltQuery = new LiveTvChannelQuery(); QueryResult<ChannelInfoDto> cInfo = await client.GetLiveTvChannelsAsync(ltQuery); string[] playList = new string[1]; foreach (ChannelInfoDto ch in cInfo.Items) { if (ch.Name.ToLower() == newChannel.ToLower()) { playList[0] = ch.Id; break; } } // Play the channel PlayRequest pr = new PlayRequest(); pr.PlayCommand = PlayCommand.PlayNow; pr.ItemIds = playList; await client.SendPlayCommandAsync(sessionID, pr);
ebr 16338 Posted March 19, 2019 Posted March 19, 2019 Can you reproduce the same problem with the web app?
BillOatman 597 Posted March 19, 2019 Author Posted March 19, 2019 I never use the web app. But I think I should be able to try it without too much effort.
