bnwbass 3 Posted May 11, 2014 Posted May 11, 2014 Hello all, What are most folks using as a player to playback audio formats DTS-HD and Dolby True-HD? Is there a plugin for MCE or is the only way to go with external 3rd party Player? Thx bw
AdrianW 1058 Posted May 11, 2014 Posted May 11, 2014 I think most people will be bitstreaming the HD audio formats to an AV receiver. So all that's required is to configure ffdshow or LAV to bitstream.
bnwbass 3 Posted May 11, 2014 Author Posted May 11, 2014 Thanks...MBT with the installed LAV works fine and my AV and decodes no problems. Can I configure the same LAV used for MBT to work the internal WMC player for media browser classic or do I need to install ffdshow? thx bw
ebr 16334 Posted May 11, 2014 Posted May 11, 2014 If you've installed LAV with MBT then it should also work with the internal WMC player. That's all I have installed.
bnwbass 3 Posted May 11, 2014 Author Posted May 11, 2014 Well maybe I have other issues then, I typically use MBC for playback and historically using TMT5 for external. I want to get away from TMT as the player. When I launch a DVD file from MBC the playback starts for about 10 seconds and then closes and goes back to the MBC theme screen. I have uninstalled all external players and reinstalled MBC but get the same result. How do I do a complete uninstall on MBC and start from fresh install of MBC?
ebr 16334 Posted May 11, 2014 Posted May 11, 2014 I don't think the MBC installation will have much effect on that. Sounds like a content or codec problem. But, you would just un-install it and then delete the ProgramData\MediaBrowser-Classic folder.
