Library not syncing
Go to solution Solved by PoBear,
Hi
I'm running Kodi 17.6 with 4.09a of the add-on and the 0.14 dependencies
I have a library that is not syncing it defined as movies but actually contains one-off programmes. Last week I added a fair amount of content to the library but none of it has shown up. I've tried doing a manual sync of the data which appeared to work but still none of the new data is showing.
My other libraries appear to be syncing OK.
Happy to provide any logs that might help, just ask.
Any ideas?
Thanks
Edited by PoBear
Angelblue05
Do provide your Kodi log yes. Was Kodi running at the time, or is content missing when you start Kodi?
The content is missing when I start Kodi.
The library is called Miscelaneous.
Log from KODI startup to after the Emby sync has completed.
kodi.log
Angelblue05
If the library type is Movies, can we focus on one item that is part of the library?
While Kodi is running, go to the webclient, edit the metadata > Save of one item. Wait a few, post that Kodi log
You don't need to edit anything, just triggering the update event using the save button. Thank you.
New log attached. I updated a file called "The Music Box" just after 22:00. I can see the file being processed in the log but it is not showing in KOdi when I look at the library, however, some msic videos that I changed earlier are showing in my MV library in Kodi.
kodi 19-03-17 @22.00.txt
  • Solution
Huge red face of embarrassment  :(
The sort order for the library in Kodi had got changed to date added and all the new files were at the end. I had even gone through the library one entry at a time (all 400+) in case the video I had changed was showing in a different place but stopped when got to Z, I had to rebuild my system a while ago so all of the "original" videos had the same add date which is why nothing looked out of place.
Really sorry for wasting your time.
  • Like 1
Guest
