valkata 0 Posted March 15, 2019 Posted March 15, 2019 Hi all, Unfortunately Emby Server 4.0.x removed some features that are a must have for me, therefore I want to downgrade to 3.5.x. Unfortunately, I have no idea how to do that... Anyone can help me with Emby Server downgrade from 4.0.x to 3.5.x?
Luke 42242 Posted March 15, 2019 Posted March 15, 2019 Hi, what features exactly are you referring to?
valkata 0 Posted March 15, 2019 Author Posted March 15, 2019 Grouping multiple libraries into one view.
Luke 42242 Posted March 15, 2019 Posted March 15, 2019 Are you aware that you can add multiple folders to a single emby library?
valkata 0 Posted March 15, 2019 Author Posted March 15, 2019 Yes, I am aware of that. My problem is that I am multilingual and have movies and TV shows from multiple countries in multiple languages. Metadata needs to be retrieved in original language. In version 3.5.x I had multiple libraries with English/Russian/German metadata then combined them into one view. In 4.0.x I either have one library with part of shows without metadata, or multiple libraries (one for each language)...
Luke 42242 Posted March 15, 2019 Posted March 15, 2019 Are you aware that you can set a default metadata language for the library, and then override per show or per movie?
valkata 0 Posted March 16, 2019 Author Posted March 16, 2019 (edited) I didn’t know that. However it is not an attractive perspective to manually set metadata language for a few dozens movies and TV shows one by one and I am not convinced. For me 4.0.x brings nothing but takes away something. So, my original question still stands: how to downgrade 4.0.x to 3.5.x on Synology DSM? Edited March 16, 2019 by valkata
