Noddyliten 2 Posted March 14, 2019 Posted March 14, 2019 Hi, I have created a user for one of my kids. He is 11 so I have granted the least user access as possible. At least I think I have. But, when i log in with this user, he can see the movie Hereditary... which he should not. I have attached screen shot from user access to show what I have granted him, and the rating in Ebmy, which shows 15 years. Am I doing something wrong or a bug?
Luke 42216 Posted March 14, 2019 Posted March 14, 2019 Actually the issue is that no-15 isn't a rating that we have in our database with a value, so it essentially becomes the equivalent of unrated. Try using the metadata editor to change the rating to one of the ones that can be selected in the editor.
Noddyliten 2 Posted March 14, 2019 Author Posted March 14, 2019 When I scroll thru the movie list and also when I search for Hereditary.
Noddyliten 2 Posted March 14, 2019 Author Posted March 14, 2019 (edited) Ok, but does it not pull the rating from IMDB? I can't manually go and change all the ratings on the movies. Where did it get the NO rating from then? I have not typed this in. In the library settings I have choosen Norway as the country setting. Is this why the tag states "NO-15"? Are u missing a mapping from different country codes to IMDB rating? Edited March 14, 2019 by Noddyliten
Luke 42216 Posted March 14, 2019 Posted March 14, 2019 Imdb is not a free and open data service. We use MovieDb. We can add some Norwegian ratings for our next release and then this title will work correct. I see a few here that we will add: https://en.wikipedia.org/wiki/Norwegian_Media_Authority Thanks.
Noddyliten 2 Posted March 14, 2019 Author Posted March 14, 2019 (edited) How do I update all of my libary to get the correct ratings then? And, I can see from the library settings that moviedb is the first Emby should choose from. Edited March 14, 2019 by Noddyliten
Luke 42216 Posted March 14, 2019 Posted March 14, 2019 Sounds like it already is correct. We will add parental control support for these ratings to our next release. Thanks.
Noddyliten 2 Posted March 14, 2019 Author Posted March 14, 2019 (edited) Welll, there are strange things going on. On my son\s Ipad I can see the image of "The Thing". But below the image it says "Submergence". And when I click on the image,information about submergence is shown. And this does not happen from my android phone. The correct movie is shown. Edited March 14, 2019 by Noddyliten
ebr 16312 Posted March 15, 2019 Posted March 15, 2019 If you want his account very restricted, you may also want to check the option to block unknown and unrated content. With that on, you would not have seen "Hereditary".
Noddyliten 2 Posted March 15, 2019 Author Posted March 15, 2019 That worked, then again, almost everything dissapared from the library:(
Luke 42216 Posted March 15, 2019 Posted March 15, 2019 Right because that means it has ratings we do not currently recognize.
Noddyliten 2 Posted March 15, 2019 Author Posted March 15, 2019 Understood. That said, I have not asked for there to be norwegian ratings. I ticked off for Norwegian in then library settings. So, I think based upon this Emby has downloaded norwegian ratings. And, then I think it is a bug actually when the mappings are not there. Anyway.. It would have been nice to be able to reset the rating tag to the international rating categories. And, not by doing this pr movie as this will take to long time. I would like to mass update the ratings for the movies.
Luke 42216 Posted March 15, 2019 Posted March 15, 2019 You got Norwegian ratings due to your metadata language & country settings. They will be added for the next release. This just never came up before. Thanks.
Noddyliten 2 Posted March 15, 2019 Author Posted March 15, 2019 Ok, thanx. And thanx for extremely fast respons!
Axachi 2 Posted February 21, 2020 Posted February 21, 2020 Well Is this fixed? I can not seem to get this to work. all my movies/TV shows have ratings from TMDB. (Internal Emby scraping) And movies and tv-shows have PG MPAA etc rating in the meta.. But I set the NO-9 or NO-12 rating on my child . She can see all the movies and tv- shows no matter what.. I have the latest Server ver. 4.3.1.0. I am not sure what else to do. If I manualy set a NO-18 rating on an R rated movie it disapares as expected. But I do not want to edit all movies for this.. My ratings-no.txt file under /config/localisation has this listed.. is this correct? NO-A,1 NO-6,5 NO-9,6 NO-12,8 NO-15,9 NO-18,10
Luke 42216 Posted February 21, 2020 Posted February 21, 2020 The file is not used anymore but yes those are the Norwegian ratings that emby has. Did you check the rating that is assigned to your movies and TV shows?
Axachi 2 Posted February 21, 2020 Posted February 21, 2020 As I said in my post all movies and TV shows have rating from internet TMDB. If I manually go into a movie. It has rating R. If I press the pulldown. I can choose R and all set NO- ratings.
Luke 42216 Posted February 21, 2020 Posted February 21, 2020 Ok i think we need to adjust the numeric mappings that we have for Norwegian ratings. At some point they got inadvertently changed and given higher assignments, and that's why the US R rated title is being allowed. We'll adjust this for the next release. Thanks.
Happy2Play 9806 Posted February 21, 2020 Posted February 21, 2020 This information needs to exist somewhere so it can easily be seen. LoadRatings("no", new[] { new ParentalRating("NO-A", 1), new ParentalRating("NO-6", 3), new ParentalRating("NO-9", 5), new ParentalRating("NO-12", 7), new ParentalRating("NO-15", 9), new ParentalRating("NO-18", 10) LoadRatings("us", new[] { new ParentalRating("TV-Y", 1), new ParentalRating("APPROVED", 1), new ParentalRating("G", 1), new ParentalRating("E", 1), new ParentalRating("EC", 1), new ParentalRating("TV-G", 1), new ParentalRating("TV-Y7", 3), new ParentalRating("TV-Y7-FV", 4), new ParentalRating("PG", 5), new ParentalRating("TV-PG", 5), new ParentalRating("PG-13", 7), new ParentalRating("T", 7), new ParentalRating("TV-14", 8), new ParentalRating("R", 9), new ParentalRating("M", 9), new ParentalRating("TV-MA", 9), new ParentalRating("NC-17", 10), new ParentalRating("AO", 15), new ParentalRating("RP", 15), new ParentalRating("UR", 15), new ParentalRating("NR", 15), new ParentalRating("X", 15), new ParentalRating("XXX", 15) I believe this is what we adjust it to, to map better.
Luke 42216 Posted February 21, 2020 Posted February 21, 2020 I gave no-15 an 8 since it would be lower than US-R. And then i have NO-18 a 9 since i'm guessing it's really meant to be more like an R rating than truly adult xxx content. But yes i've wanted to make these mappings configurable for a long time, just haven't gotten there yet.
