Tupsi 4 Posted March 14, 2019 Posted March 14, 2019 I upgraded from an earlier beta (think it was .10 or .12), sadly the db changed and now I can not go back as this version seems to have been compiled for freebsd 12 while my freenas still has 11.2. I got a warning on the command line, but after I said "no" it still installed it anyway, so I guess I now either have to wait till a new beta is out which is kinda nicer to my system or go back to the stable release in the hope it now works with my freenas freebsd (moved to beta over christmas because of that ffmpeg problem).
Luke 42239 Posted March 14, 2019 Posted March 14, 2019 I think going forward the freenas plugin will be best.
Tupsi 4 Posted March 15, 2019 Author Posted March 15, 2019 I think going forward the freenas plugin will be best. Aye, that was my first idea as well, right after I made this post. So I fired up my admin gui, but sadly it still says 3.5.3 there. Are there any plans to bump this to 4.x soon their as well from your end?
Luke 42239 Posted March 16, 2019 Posted March 16, 2019 Yea I think we're going to have to take that over.
makarai 109 Posted March 19, 2019 Posted March 19, 2019 Yea I think we're going to have to take that over. As i have mentioned before. I am glad you have updated the ports tree with the recent stable, that will eliminate a lot of problems in the future. We just have to wait until 4.2 makes it into the FreeNAS quarterly package tree. It's a shame tho that you guys went for the FreeBSD 12 as the stable for the recent build.
sluggo45 47 Posted March 20, 2019 Posted March 20, 2019 If you are already on the 4.1.x beta train you can't downgrade to 4.0.x whether the plugin/port is available or not, FYI. Database is incompatible. You can use the server backup plugin, export watched data, etc. to make the rebuild easier, but you will have to rebuild if you go back.
Tupsi 4 Posted March 21, 2019 Author Posted March 21, 2019 If you are already on the 4.1.x beta train you can't downgrade to 4.0.x whether the plugin/port is available or not, FYI. Database is incompatible. You can use the server backup plugin, export watched data, etc. to make the rebuild easier, but you will have to rebuild if you go back. hehe, guess what? I allready learned that the hard way after having a fucked up upgraded 4.1.x with the latest 12 issues and FreeNAS :-) So I just installed a new one from scratch and clicked like half an hour the "already watched" buttons on the new installation... Staying put with this 4.0.2 for now
sluggo45 47 Posted March 21, 2019 Posted March 21, 2019 I forgot Emby is weird about watched data. Still, for future reference, Trakt will work, if you're willing to export data to it, then re-import it. That method gets problematic for multiple users, but for single it's fine.
chaosmonger777 0 Posted March 31, 2019 Posted March 31, 2019 Just out of curiosity: why is the beta build on FreeBSD 12? FreeBSD users tend not to jump on the newest train. In my experience they (including me) tend to wait till 12.1 or 12.2 is out. Normally commercial software continues to build on 11 and adds the dependency for the 11 libs (https://svnweb.freebsd.org/ports/head/misc/compat11x/) in the port. Is there a special reason for this?
sluggo45 47 Posted April 1, 2019 Posted April 1, 2019 Lot of us asking that question. It was probably requested by someone, and the Emby staff knows it's technically the latest supported release (though I agree with you that most FreeBSD users are pretty conservative about updating major releases) so they moved it, unaware it would break the beta's for FreeNAS users as well as any other FreeBSD user on 11.x. It's been said before but the simplest way for the Emby devs to fix this is to just go back to compiling it for 11.x (11.2) because FreeBSD users who are using 12 have the easy option to create a jail based off 11.2 whereas it does not work the opposite way.
Luke 42239 Posted April 1, 2019 Posted April 1, 2019 We should have betas for freenas again soon. thanks guys. 2
sluggo45 47 Posted April 7, 2019 Posted April 7, 2019 @@Luke any change with the latest betas like 4.1.0.22?
Luke 42239 Posted April 7, 2019 Posted April 7, 2019 Not yet. We are working on setting up a second build environment for freenas. It will 1-2 more weeks until this is ready. Thanks. 1
