xnappo 1611 Posted May 10, 2014 Posted May 10, 2014 All, I thought there was a problem with Aeon Nox - but it is not. It is either something broken in our image server or in the MB3 server. After deleting my Textures.db - all art being served no longer has proper transparency - there is a black background. Examples below on ClearArt/Logos/Discs: (Annie ClearArt) (Anonymous Discart) (Archer Logo) @ - did you make any changes on our side? xnappo
Solution xnappo 1611 Posted May 10, 2014 Author Solution Posted May 10, 2014 Changing the service to return PNG instead of JPG fixed this. Checked in. Any need for JPG? xnappo
im85288 1493 Posted May 10, 2014 Posted May 10, 2014 Cool, PNGs for transparency and JPG for keeping the image size down I guess...wonder why it was not there before though....
im85288 1493 Posted May 10, 2014 Posted May 10, 2014 (edited) Is file size such a problem that it needs these switches put in? Does that not just over complicate things. Edited May 10, 2014 by im85288
xnappo 1611 Posted May 10, 2014 Author Posted May 10, 2014 Yeah - it all gets converted when it goes in the TexturesDB anyway right?
Koleckai Silvestri 1154 Posted May 10, 2014 Posted May 10, 2014 I switched to jpg images a week or two back. JPG images do not support transparency of any kind.
