Dizzy49 99 Posted March 14, 2019 Posted March 14, 2019 I have a Fire Medallion that I've been using for travel for a while. It's great being able to plug it into the TV at the hotel and watch my stuff from my hotel. The past week and a half I have noticed that the audio starts slightly out of sync and the sync gets worse as the show progresses. If I pause it, or even exit the show, start a new show and then go back it remains out of sync with the sync as bad as when I paused/stopped the video. I have it connected via LAN cable (using an Amazon Lan/Power dongle). Anyone else having issues?
Luke 42246 Posted March 14, 2019 Posted March 14, 2019 Hi there, can you please go over an example? Thanks.
boogmeister1 2 Posted March 15, 2019 Posted March 15, 2019 (edited) I have a Fire Medallion that I've been using for travel for a while. It's great being able to plug it into the TV at the hotel and watch my stuff from my hotel. The past week and a half I have noticed that the audio starts slightly out of sync and the sync gets worse as the show progresses. If I pause it, or even exit the show, start a new show and then go back it remains out of sync with the sync as bad as when I paused/stopped the video. I have it connected via LAN cable (using an Amazon Lan/Power dongle). Anyone else having issues? I actually experienced the same symptoms this week when connected to an RV park wifi. The programs would start playing with no problems and then it seemed as though the audio would go out of sync... maybe it's just me, but it seemed like it would happen during commercials. I would exit back to the guide and select the program again and it would be fine until the next commercial break. I was using a fireTV Pendant over wifi. Edited March 15, 2019 by boogmeister1
Dizzy49 99 Posted March 15, 2019 Author Posted March 15, 2019 I just started a show. It was in sync at the beginning, but now it's 4min into the show and almost 1/2 sec out of sync Here are some logs for you: embyserver.txt ffmpeg-transcode-4f43f90e-ad6f-46c7-85ed-e090b3bfa03a_1.txt
Dizzy49 99 Posted March 15, 2019 Author Posted March 15, 2019 No, I did not do any seeking. It seems OK on the web app (connected using the same wifi).
ebr 16338 Posted March 15, 2019 Posted March 15, 2019 Is the web app playing it the exact same way? You have an ffmpeg log from that to compare?
Dizzy49 99 Posted March 20, 2019 Author Posted March 20, 2019 Everything is working fine at the house. I'll have to wait until I'm back at the hotel next week to try again. The web app played it fine. Do you still want a log?
ebr 16338 Posted March 20, 2019 Posted March 20, 2019 Let's wait until you can reproduce the issue. Thanks.
Dizzy49 99 Posted April 4, 2019 Author Posted April 4, 2019 Ok, I'm back at the hotel, and I've been watching a bunch of stuff tonight. I paused one of the shows for a while and when I came it drifted out of sync. The next show I watched started out of sync. I checked my decoder settings and there was nothing listed under the hardware decoders, or encoders. I restarted the server and they came back, but nothing was checked. I moved DXVA2 to the top and made sure it was the only one checked in each area. I reconnected and played the video and it's still out of sync. I even did a Force Stop on Emby and tried again, and it is still out of sync. Kind of at a loss here. Here are a bunch of logs to work with. embyserver.txt ffmpeg-transcode-672b35ae-ff96-45fa-ac6c-c174b7389bd5_1.txt ffmpeg-transcode-f18e6418-aa80-4318-b295-47b67039b921_1.txt ffmpeg-transcode-4766e07c-9b12-434b-bcf2-06f8fb138b3f_1.txt ffmpeg-transcode-e27ef658-3d7a-4696-bb76-590be3f48d12_1.txt hardware_detection-63689940103.txt
ebr 16338 Posted April 4, 2019 Posted April 4, 2019 Did you play with the web app too to compare behavior?
Dizzy49 99 Posted April 7, 2019 Author Posted April 7, 2019 (edited) Did you play with the web app too to compare behavior? Yes, I have mentioned several times that I have had no issues with the web app. I also have no issues with Emby Theater. Last night my wife was watching something on our network, and the audio was slightly off. Barely noticable, but it is present on the local network too. She was using a Fire Cube to watch stuff. Edited April 7, 2019 by Dizzy49
ebr 16338 Posted April 7, 2019 Posted April 7, 2019 Yes, I have mentioned several times that I have had no issues with the web app. I also have no issues with Emby Theater. Last night my wife was watching something on our network, and the audio was slightly off. Barely noticable, but it is present on the local network too. She was using a Fire Cube to watch stuff. Right but then I asked you to get me an ffmpeg log from the web app to compare to the same playback on this app. That is what I'm after... Thanks.
Dizzy49 99 Posted April 8, 2019 Author Posted April 8, 2019 Right but then I asked you to get me an ffmpeg log from the web app to compare to the same playback on this app. That is what I'm after... Thanks. Ahhhhhhhhhhhhhhhhhhhhhh, gotcha. I'll keep that in mind this coming week.
Dizzy49 99 Posted April 17, 2019 Author Posted April 17, 2019 Ok, so here's one for you. I was watching it on the app on my phone and it just stopped completely. I came back to my hotel to watch it on the Amazon Fire and the audio is messed up. When I play it via the webapp, it plays fine. You may need to dig for the earlier one, but it's the same file in all the issues I had. I hope these are all the files you need: embyserver.txtffmpeg-transcode-3ae2e440-1183-41f9-889a-499ba0125828_1.txtffmpeg-transcode-1864b9da-c8cc-4084-9cb2-bad4faed5674_1.txtffmpeg-transcode-48ffd474-addc-4160-bd6b-1f6568219cb1_1.txtffmpeg-transcode-30680c7e-8d40-496b-bc85-70d58fa5fbc7_1.txt
ebr 16338 Posted April 17, 2019 Posted April 17, 2019 Ok, so here's one for you. I was watching it on the app on my phone and it just stopped completely. I came back to my hotel to watch it on the Amazon Fire and the audio is messed up. When I play it via the webapp, it plays fine. You may need to dig for the earlier one, but it's the same file in all the issues I had. I hope these are all the files you need: embyserver.txtffmpeg-transcode-3ae2e440-1183-41f9-889a-499ba0125828_1.txtffmpeg-transcode-1864b9da-c8cc-4084-9cb2-bad4faed5674_1.txtffmpeg-transcode-48ffd474-addc-4160-bd6b-1f6568219cb1_1.txtffmpeg-transcode-30680c7e-8d40-496b-bc85-70d58fa5fbc7_1.txt Hi. I need to know which log goes with which playback and what exactly happened during that playback. The best thing to do is reproduce a single problem or scenario and then provide just the log from that scenario. Thanks.
