Natilus13 14 Posted March 13, 2019 Posted March 13, 2019 Hello all, Has anyone else run into issues with playback when off your local network? I have had users reporting this recently (I believe only since updating to server v4.x) and have not had any luck in resolving it, I have tried adjusting the transcoding options, and even turning it off. I have also had the users try using much lower quality settings on their end. It all made no difference. Users are trying to playback files using various methods and it is always them same. While on my LAN, everything runs smooth as butter though. Would love to get some help trying to troubleshoot this. Thanks!N
Luke 42239 Posted March 13, 2019 Posted March 13, 2019 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. thanks !
Natilus13 14 Posted March 18, 2019 Author Posted March 18, 2019 Thanks Luke. I haven't had a chance to test this, and am waiting to hear back from one of my friends when they connect, regarding when they have this problem. Once I get a the time narrowed down, I'll report back.
Natilus13 14 Posted March 18, 2019 Author Posted March 18, 2019 @@Luke I just sent you my logs in a PM. Thanks.
Natilus13 14 Posted March 25, 2019 Author Posted March 25, 2019 @@Luke Good morning. Any update on this? Is there any other information you need me to send you? Thanks,Nathan
Luke 42239 Posted March 25, 2019 Posted March 25, 2019 I have not been able to reproduce, but i would have them try lowering the in-app quality settings again.
Natilus13 14 Posted March 25, 2019 Author Posted March 25, 2019 Thanks. I've tried that and still had the issue. I believe generally they would have the quality set to "Auto", but I will ask them to try again and report back. Thanks,Nathan
Natilus13 14 Posted March 25, 2019 Author Posted March 25, 2019 Spoke with one of my users. Apparently when they play anything on their TV's built in browser, it plays fine but they have no option for full screen playback. When they try and use a browser on a computer, Mac or Linux, they get the freezing issue. They have tried dropping the playback quality but it hasn't helped.
Luke 42239 Posted March 26, 2019 Posted March 26, 2019 Can you have them try a different video file? thanks.
Natilus13 14 Posted March 26, 2019 Author Posted March 26, 2019 It seems to be happening with any file they try and play.
Natilus13 14 Posted March 26, 2019 Author Posted March 26, 2019 Sure thing. Funny that they happened to pick an AVI. The majority of the files are MKV, with only a handful of AVI. I can try testing tomorrow when I am in the office and will report back. Really appreciate your help with this @@Luke Cheers,N
Natilus13 14 Posted March 27, 2019 Author Posted March 27, 2019 So today I am at the office and have had no playback issues. I checked with a few of my friends and they also had no issues with anything they played yesterday either. This is confusing. Originally I tried adjusting some of the transcoding settings. When that made no difference, I switched everything back to how it was originally. Now everything is working. Not sure why, but I'll take it ;-) Sorry to have bothered you with this @@Luke Cheers,N
flossiejayno 7 Posted April 3, 2019 Posted April 3, 2019 Hi, I believe I'm having the same problem. I'm using emby outside the lan and having issues with the playback stuttering occasionally. I'm wondering if it's because I'm recording liveTV shows around the same time? I'm not 100 on this though. I have attached relevant log files. Emby Server = 4.0.2.0 Mac Mini 2012 i5 16GB ram OSX High Sierra Unfortunately I'm away from home and cannot give you the exact OSX details. embylog.txt ffmpeg-remux-4bd0fa1a.txt record-transcode-43b2c5a5.txt record-transcode-3973dd29-71ae.txt
flossiejayno 7 Posted April 3, 2019 Posted April 3, 2019 Emby Admin can you please remove my log files from the post once you have read my post. Thanks Phil
flossiejayno 7 Posted April 3, 2019 Posted April 3, 2019 Here is another server log with the playback stalling Cheers Phil embyserver.txt
Natilus13 14 Posted April 3, 2019 Author Posted April 3, 2019 @@flossiejayno Do you have throttling enabled for transcoding? I did notice the other day that when one user mentioned about some freezing, they ended up not having anything buffered. I turned off the throttling and that sorted out his issue. You need to be careful though, as this can really boost CPU usage.
flossiejayno 7 Posted April 3, 2019 Posted April 3, 2019 @@flossiejayno Do you have throttling enabled for transcoding? I did notice the other day that when one user mentioned about some freezing, they ended up not having anything buffered. I turned off the throttling and that sorted out his issue. You need to be careful though, as this can really boost CPU usage. Hi, Thanks for replying so fast. Yes throttling was enabled. However the last embyserver log I uploaded with the stuttering video play mode was "direct play". I have disabled the throttling to see what happens. In the latest log it appears to reconnect or restart the playing of the video as the response time is large e.g. Time: 13257ms and the video name call is listed instead of just the progress call. Though please note I have no idea how to read the log so could be completely wrong.
Natilus13 14 Posted April 3, 2019 Author Posted April 3, 2019 It may not make any difference for you, just thought it was worth mentioning it since it seemed to resolve the issue for at least one of my users
flossiejayno 7 Posted April 3, 2019 Posted April 3, 2019 @@Natilus13 No problem thank for your help...
flossiejayno 7 Posted April 3, 2019 Posted April 3, 2019 This file is embyserver log is with "enable debug logging" checked Thanks Phil
Luke 42239 Posted April 4, 2019 Posted April 4, 2019 I notice you have the quality setting in the video player set to roughly 4.5 mbps. Please try lowering this to 1 mbps and then see how that compares. Thanks.
flossiejayno 7 Posted April 4, 2019 Posted April 4, 2019 I notice you have the quality setting in the video player set to roughly 4.5 mbps. Please try lowering this to 1 mbps and then see how that compares. Thanks. Hi Luke, Are you meaning the User internet streaming bitrate limit? As this is not set. Otherwise where do I find this option? Thanks Phil
Luke 42239 Posted April 6, 2019 Posted April 6, 2019 Hi Luke, Are you meaning the User internet streaming bitrate limit? As this is not set. Otherwise where do I find this option? Thanks Phil It would be the quality setting from the app that you're playing with, and it may also be directly in the video player as well depending on what app you're playing from. Please let me know if this helps. Thanks.
