ifignella 12 Posted March 13, 2019 Posted March 13, 2019 I'm seeing two of every collection, does anyone know why this might be?
ebr 16346 Posted March 13, 2019 Posted March 13, 2019 Hard to know from just that information but, have you put the same physical path into more than one library?
ifignella 12 Posted March 14, 2019 Author Posted March 14, 2019 (edited) Sorry ebr. I only have 2 libraries, tv and movies. There is only a single folder for each library. I tried uninstalling/reinstalling the plugin, still doubles though. Somehow they are connected. If I choose a movie in one collection (example: Bourne Collection) and play/stop, then go to the same movie in the other collection folder (copy of Bourne Collection) it will resume where I left off in the first one. I deleted the library and added it back in. Still the same. *edit - I cleared out the data/collections folder. Seems to have fixed it. Edited March 14, 2019 by ifignella
Luke 42255 Posted March 14, 2019 Posted March 14, 2019 What if you delete both die hard collection entries? do two come back later, or just one?
Happy2Play 9814 Posted March 14, 2019 Posted March 14, 2019 Do they both appear in Metadata Manager? Do both collections have the same path in edit metadata?
Riggs 312 Posted April 16, 2019 Posted April 16, 2019 @@Luke to avoid open a new topic about Box Sets plugin, I have a question: Is it necessary to have the plugin installed to create/re-create the collections? Explanation: I had a problem with that plugin yesterday because I changed the paths of the HDD's, and after updating the paths on the Emby server, everything was restored almost in real time, but the collections were only partially restored. I tried to update the libraries in all possible ways and it did not work, I also refreshed the boxsets from the plugin but it did not work either. Today I tried again, and nothing, the collections were the same as yesterday, partially created/recreated but not complete. Today, it occurred to me to uninstall the plugin, and again updated the libraries, and ...voilá! in a matter of seconds everything was complete in the collections department. Remember that I have Emby Premiere and I do not know if that is relevant to what I'm asking. Thanks in advance.
ebr 16346 Posted April 16, 2019 Posted April 16, 2019 @@Luke to avoid open a new topic about Box Sets plugin, I have a question: Is it necessary to have the plugin installed to create/re-create the collections? Yes, it is necessary to have the plug-in installed in order to create the box sets. However, whatever ones are created will still be there if you uninstall the plug-in. That sounds like what happened to you.
Riggs 312 Posted April 16, 2019 Posted April 16, 2019 Yes, it is necessary to have the plug-in installed in order to create the box sets. However, whatever ones are created will still be there if you uninstall the plug-in. That sounds like what happened to you. I gonna re-install it back. What i wonder is why after uninstall it, all collections backed to normal. I let you know if something happens with the collections after reinstall it. Thanks for your quick answer
Riggs 312 Posted April 16, 2019 Posted April 16, 2019 (edited) Everything is ok Can be bcause i receive a lot of this and the plugin was outdated? Check for application updates failed 4/16/2019, 8:09:31 am Running time: 0 seconds Check for plugin updates failed 4/16/2019, 8:09:31 am Running time: 0 seconds And that's not an internet connection problem, happens a lot after migrate from W10Pro to Linux Fedora Edited April 16, 2019 by HRSCR
Luke 42255 Posted April 16, 2019 Posted April 16, 2019 Sounds like a network problem checking for updates.
Riggs 312 Posted April 16, 2019 Posted April 16, 2019 Sounds like a network problem checking for updates. What kind? I found many times that message working in the computer, i cross check with pfsense logs and i can't find any issue on lan or wan at the hours that the problem happens, and only happens with Emby
Riggs 312 Posted April 16, 2019 Posted April 16, 2019 @@Luke No such device or addressat Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod)at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod)at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePackagesWithoutRegistrationInfo(Boolean enableCache, CancellationToken cancellationToken)at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePluginUpdates(Version applicationVersion, CancellationToken cancellationToken)at Emby.Server.Implementations.ScheduledTasks.PluginUpdateTask.Execute(CancellationToken cancellationToken, IProgress`1 progress)at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options)
Riggs 312 Posted April 16, 2019 Posted April 16, 2019 That token is the premiere key? maybe is outdated at your side? i checked if it is the last one, and it is. i s set in the Emby Server
Luke 42255 Posted April 17, 2019 Posted April 17, 2019 That token is the premiere key? maybe is outdated at your side? i checked if it is the last one, and it is. i s set in the Emby Server What are you referring to?
