TheVideoMan 0 Posted March 12, 2019 Posted March 12, 2019 Hello, my first post here, and have to say I am loving emby. However I am having a small problem with the library on Android tv. Basically all cover art is shown bunched up and overlapping each other. I'm not sure if this is a known issue or not. Home screen also looks to zoomed in? Anyway I am sure my terrible description of the issue dose not help. So I have attached an image. http://i63.tinypic.com/11vr2ph.jpg
ebr 16338 Posted March 13, 2019 Posted March 13, 2019 Hi. What is this device? Not a true Android TV box, correct...?
TheVideoMan 0 Posted March 13, 2019 Author Posted March 13, 2019 Hi yes, it is not an android tv os device. It was originally running android 7.1 and had this issue then. The device is an old X96 mini that I have for the bedroom. I then flashed with atvExperience. And still the same, I presumed that it was crap hardware that was to blame. But because I have had no other issues with any other apps I thought I would mention it here to see if it was just a bug.
ebr 16338 Posted March 20, 2019 Posted March 20, 2019 Well it is related to it not being a true TV OS so the screen dimensions are not what are expected by the app. I can check to see if there is anything in this specific area that can be done in this instance. 1
TheVideoMan 0 Posted March 28, 2019 Author Posted March 28, 2019 Hi any update on a possible solution? and can you tell me if this would be the same issue with all Android TV OS boxes, (Would Xiaomi Mi be the same?)
ebr 16338 Posted March 28, 2019 Posted March 28, 2019 Any of the true official Android TV boxes would not have this issue. Thanks.
TheVideoMan 0 Posted April 9, 2019 Author Posted April 9, 2019 (edited) Any of the true official Android TV boxes would not have this issue. Thanks. Hey thanks for the help, but I swapped to Jellyfins beta and its working perfect. they seam to have fixed your issue. Thanks anyways. Edited April 9, 2019 by TheVideoMan
ebr 16338 Posted April 9, 2019 Posted April 9, 2019 I don't believe they have this exact same view (or a multitude of other features). However, we will take a more in-depth look at this particular issue in the near future. Thanks.
TheVideoMan 0 Posted April 14, 2019 Author Posted April 14, 2019 Hey thanks for taking a second look. But just to clarify I am just using Jellyfin client app for Android TV. I am using this with my emby Premiere subscription server. (with no plans to cancel it) I pointed it out so as to help anybody else who has one of these cheap Android TV boxes lying around and dose not want to go back to plex. It has solved most of my library view problems. Even the live TV guide is working with it. So there must be a solution that you guys can come up with that could fix this. Thanks again.
ebr 16338 Posted April 15, 2019 Posted April 15, 2019 Hey thanks for taking a second look. But just to clarify I am just using Jellyfin client app for Android TV. I am using this with my emby Premiere subscription server. (with no plans to cancel it) I pointed it out so as to help anybody else who has one of these cheap Android TV boxes lying around and dose not want to go back to plex. It has solved most of my library view problems. Even the live TV guide is working with it. So there must be a solution that you guys can come up with that could fix this. Thanks again. Their app doesn't have the same view where you are having this issue in ours. In fact, their app will be missing a lot of functionality that our app does and is using some very old versions of things like the player. Just so you are aware. Thanks.
