rapteev 20 Posted March 12, 2019 Posted March 12, 2019 Hi If I create a mixed library with movies and series on emby server, the server respects that and shows the mixed content, but on emby for kodi I cannot used the mixed library because emby for kodi shows two separate libraries (one for movies and one for series) when I want just one with the mixed content. It is possible to implement this? Thank you very much.
sualfred 677 Posted March 12, 2019 Posted March 12, 2019 Not possible, because Kodi doesn't support real mixed contents and multiple libraries. 1
Angelblue05 4132 Posted March 12, 2019 Posted March 12, 2019 (edited) If you want them to appear together, do not sync the library. The dynamic entry for mixed content is able to display both within the same listing. It's just a bit slower to load if you have a lot of content, but might be worth the trade off for you. Open Emby for Kodi > open the context menu on your mixed library > remove library from Kodi. Then access your library (you may need to back out first). Edited March 13, 2019 by Angelblue05
