slupmada 0 Posted March 12, 2019 Posted March 12, 2019 I have a Mixed Content library that has all of the TV I record, including movies, series, sports, etc. It seems lately that several (not all) series are being identified as movies. When I try to update the metadata, the option to enter a TVDB ID is missing, and only shows fields for IMDb and TheMovieDb. I'm running server version 4.0.2.0 on Windows 7 x64 Professional. Here is the library's folder structure: Recorded TV Series 1 SeriesTitle-EpisodeTitle-SXXEXX.wtv SeriesTitle-EpisodeTitle-SXXEXX.wtv Series 2 SeriesTitle-EpisodeTitle-SXXEXX.wtv SeriesTitle-EpisodeTitle-SXXEXX.wtv RecordedMovieTitle (YrReleased) RecordedMovieTitle (YrReleased).wtv Another thing I noticed with the series that are being detected as movies, is that there is now a “Version” dropdown menu, where I can select the different episodes (or supposed to be movie chapters???) of a series (see screenshot). Am I doing something wrong or was something changed in a recent update? Thanks!
ebr 16313 Posted March 12, 2019 Posted March 12, 2019 This is almost certainly a naming problem. Can you please show us a specific example with the real names of the items? Thanks.
slupmada 0 Posted March 12, 2019 Author Posted March 12, 2019 Yes, please see attached. I neglected to mention in the first post that some of these folders also contain comskip output files. Is that a problem? Some of the series folders do not have comskip files, but still appear as movies in the library. Thanks in advance!
ebr 16313 Posted March 12, 2019 Posted March 12, 2019 Okay, this is one of the complications with "mixed" content types. That setup matches our movie multi-version naming scheme. Try re-naming the folder to "The Titan Games (2019)".
slupmada 0 Posted March 12, 2019 Author Posted March 12, 2019 That worked, thank you! Do I need to do that for the rest of the series that are like that? Do I need to add the specific year it was released, or any year?
ebr 16313 Posted March 12, 2019 Posted March 12, 2019 It needs to be the proper year or you will have identification problems. The key here is I broke this constraint for multi-version videos by renaming the folder: Each version must begin with the folder name, followed by " - "
slupmada 0 Posted March 12, 2019 Author Posted March 12, 2019 The key here is I broke this constraint for multi-version videos by renaming the folder: Each version must begin with the folder name, followed by " - " Sorry, I don't know what this means. Is there an original post I can read for more information?
slupmada 0 Posted March 12, 2019 Author Posted March 12, 2019 Sorry, I don't know what this means. Is there an original post I can read for more information? I think I found it: https://github.com/MediaBrowser/Wiki/wiki/TV-naming
slupmada 0 Posted March 13, 2019 Author Posted March 13, 2019 So I think I've corrected the naming issue... now, however, I'm noticing that if I only have one episode of a series in a folder, it is also detected as a movie. Are there any suggestions for that? Thanks again for the help!
Happy2Play 9806 Posted March 13, 2019 Posted March 13, 2019 So I think I've corrected the naming issue... now, however, I'm noticing that if I only have one episode of a series in a folder, it is also detected as a movie. Are there any suggestions for that? Thanks again for the help! You will need to go over the specific example.
slupmada 0 Posted March 13, 2019 Author Posted March 13, 2019 Sure. For example, I have a series folder for Superstore, and it only has one episode in the folder (superstore_folder.png). Emby detects this file as a movie, does not provide a TVDBId field (superstore_editMetadata.png) and does not pull in any wallart (superstore_emby). I've noticed that if the series folder has more than one episode in the same folder, Emby would then detect it as a series and work properly. Am I still naming something incorrectly? Thanks!
ebr 16313 Posted March 13, 2019 Posted March 13, 2019 That is going to look just like movie to Emby. Try creating a "Season 04" folder under "Superstore" and moving the files there.
Luke 42217 Posted March 13, 2019 Posted March 13, 2019 Right, for mixed content libraries you really need to use season folders.
slupmada 0 Posted March 13, 2019 Author Posted March 13, 2019 Looks like that worked! Thanks for the tips!
