CChris 59 Posted March 12, 2019 Posted March 12, 2019 Hi. I am not sure, if this is an issue in emby, but I have one movie with some "strange" sound issues when I play it in the emby web app. The Movie is "Interstellar" - it has Dolby Digital 5.1 (english), DTS 5.1 (english) and DTS 5.1 (german)When I select the DTS 5.1 Audio Track, I have some strange noise in specific sceenes - it sounds like "crk crk crk"...It happens on the english and german DTS Audio Track, but not with the Dolby Digital Audio Track.I watched the Movie on my computer with a smaller Logitech Stereo Setup and a Subwoofer.The noise keep persistent when I reduce the volume - the "crk crk crk" is getting louder or quiter when I change the volume - so it is not related to the speaker itself.I could not hear these sounds while playing the movie directly in VLC - but I need to switch to mono in the VLC Audio settings in order to get the soundtrack, the background sounds and the dialogs. I don't know, how I can explain it more clear or how I could show what exactly I mean... If needed, I could provide access to the movie in my emby setup in a Private Message - maybe, this would help.Maybe, the Log from ffmpeg_remux could help? Application version: 4.0.2.0 http://media.caina.de:8096/emby/videos/29130/hls1/main/34.ts?DeviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzcyLjAuMzYyNi45NiBTYWZhcmkvNTM3LjM2fDE1NDk5MjY1Mzk3MDQ1&MediaSourceId=712d626d1eb5bfb4bfcbdef3336fd687&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=159872000&AudioBitrate=128000&PlaySessionId=d0e033c70a114669b9f2162f135685a4&api_key=a03dcdea0a2c49a5a80cb407d1bb204c&AudioStreamIndex=3&SubtitleMethod=Encode&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=51&TranscodeReasons=AudioCodecNotSupported {"Protocol":"File","Id":"712d626d1eb5bfb4bfcbdef3336fd687","Path":"/volume1/video/emby/Movies/Interstellar (2014)/Interstellar (2014).mkv","Type":"Default","Container":"mkv","Size":16681573576,"Name":"Interstellar (2014)","IsRemote":false,"RunTimeTicks":101439360000,"ReadAtNativeFramerate":false,"DiscardCorruptPts":false,"FillWallClockDts":false,"IgnoreDts":false,"IgnoreIndex":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":true,"MediaStreams":[{"Codec":"h264","ColorTransfer":"bt709","ColorPrimaries":"bt709","ColorSpace":"bt709","TimeBase":"1/1000","CodecTimeBase":"1001/48000","VideoRange":"SDR","DisplayTitle":"1080p H264","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":13155898,"BitDepth":8,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":804,"Width":1920,"AverageFrameRate":23.9760246,"RealFrameRate":23.9760246,"Profile":"High","Type":"Video","AspectRatio":"2.40:1","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":40,"IsAnamorphic":false},{"Codec":"dts","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Surround","DisplayTitle":"Eng DTS 5.1 Default","IsInterlaced":false,"ChannelLayout":"5.1","BitDepth":24,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"DTS-HD MA","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"ac3","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Surround","DisplayTitle":"Eng Dolby Digital 5.1","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":640000,"Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"dts","Language":"ger","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Surround","DisplayTitle":"Ger DTS 5.1","IsInterlaced":false,"ChannelLayout":"5.1","BitDepth":24,"Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Profile":"DTS-HD MA","Type":"Audio","Index":3,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"PGSSUB","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Eng","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":4,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"PGSSUB","Language":"ger","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Ger","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":5,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"Formats":[],"Bitrate":13155898,"RequiredHttpHeaders":{}} User policy for Christoph.Caina: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ss 00:03:24.000 -noaccurate_seek -f matroska -i file:"/volume1/video/emby/Movies/Interstellar (2014)/Interstellar (2014).mkv" -threads 0 -map 0:0 -map 0:3 -map -0:s -c:v:0 copy -bsf:v h264_mp4toannexb -copyts -vsync -1 -codec:a:0 libmp3lame -metadata:s:a:0 language=ger -disposition:a:0 default -ac:a:0 2 -ab:a:0 128000 -af:a:0 "volume=2" -f segment -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 -start_at_zero -segment_time 6 -segment_time_delta -204 -individual_header_trailer 0 -break_non_keyframes 1 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 34 -segment_list "/var/packages/EmbyServer/target/var/transcoding-temp/873de9408f96fcd33fa764fb9018ef5b.m3u8" -y "/var/packages/EmbyServer/target/var/transcoding-temp/873de9408f96fcd33fa764fb9018ef5b%d.ts" ffmpeg version 4.0.2-emby_2018_12_09-20190209T164910UTC Copyright (c) 2000-2018 the FFmpeg developers built with gcc 7.3.0 (GCC) configuration: --prefix=/var/packages/EmbyServer/target/ffmpeg --enable-cross-compile --cross-prefix=x86_64-syno-linux-gnu- --target-os=linux --disable-rpath --enable-pthreads --arch=x86_64 --enable-libzimg --enable-libmfx --enable-vaapi --enable-x86asm --enable-gpl --enable-shared --disable-static --disable-debug --disable-ffplay --disable-doc --disable-htmlpages --disable-manpages --disable-podpages --disable-txtpages --enable-gnutls --enable-libass --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libfreetype --enable-fontconfig --enable-gray --enable-libfribidi --enable-libvidstab --enable-libzvbi --disable-indev=sndio --disable-outdev=sndio --extra-version=20190209T164910UTC --extra-libs='-luuid -lstdc++' libavutil 56. 14.100 / 56. 14.100 libavcodec 58. 18.100 / 58. 18.100 libavformat 58. 12.100 / 58. 12.100 libavdevice 58. 3.100 / 58. 3.100 libavfilter 7. 16.100 / 7. 16.100 libswscale 5. 1.100 / 5. 1.100 libswresample 3. 1.100 / 3. 1.100 libpostproc 55. 1.100 / 55. 1.100 [matroska,webm @ 0x7c5f40] Could not find codec parameters for stream 4 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size Consider increasing the value for the 'analyzeduration' and 'probesize' options [matroska,webm @ 0x7c5f40] Could not find codec parameters for stream 5 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size Consider increasing the value for the 'analyzeduration' and 'probesize' options Input #0, matroska,webm, from 'file:/volume1/video/emby/Movies/Interstellar (2014)/Interstellar (2014).mkv': Metadata: title : Interstellar encoder : libebml v1.3.6 + libmatroska v1.4.9 creation_time : 2019-03-11T19:34:49.000000Z Duration: 02:49:03.94, start: 0.000000, bitrate: 13155 kb/s Chapter #0:0: start 0.000000, end 575.366000 Metadata: title : Chapter 1 Chapter #0:1: start 575.366000, end 1032.323000 Metadata: title : Chapter 2 Chapter #0:2: start 1032.323000, end 1500.708000 Metadata: title : Chapter 3 Chapter #0:3: start 1500.708000, end 2145.185000 Metadata: title : Chapter 4 Chapter #0:4: start 2145.185000, end 2536.826000 Metadata: title : Chapter 5 Chapter #0:5: start 2536.826000, end 3019.600000 Metadata: title : Chapter 6 Chapter #0:6: start 3019.600000, end 3287.785000 Metadata: title : Chapter 7 Chapter #0:7: start 3287.785000, end 3539.453000 Metadata: title : Chapter 8 Chapter #0:8: start 3539.453000, end 3974.971000 Metadata: title : Chapter 9 Chapter #0:9: start 3974.971000, end 4648.102000 Metadata: title : Chapter 10 Chapter #0:10: start 4648.102000, end 5132.002000 Metadata: title : Chapter 11 Chapter #0:11: start 5132.002000, end 5671.958000 Metadata: title : Chapter 12 Chapter #0:12: start 5671.958000, end 6374.660000 Metadata: title : Chapter 13 Chapter #0:13: start 6374.660000, end 6934.511000 Metadata: title : Chapter 14 Chapter #0:14: start 6934.511000, end 7334.327000 Metadata: title : Chapter 15 Chapter #0:15: start 7334.327000, end 7976.844000 Metadata: title : Chapter 16 Chapter #0:16: start 7976.844000, end 8453.779000 Metadata: title : Chapter 17 Chapter #0:17: start 8453.779000, end 9312.053000 Metadata: title : Chapter 18 Chapter #0:18: start 9312.053000, end 9839.830000 Metadata: title : Chapter 19 Chapter #0:19: start 9839.830000, end 10143.884000 Metadata: title : Chapter 20 Stream #0:0: Video: h264 (High), yuv420p(tv, bt709, progressive), 1920x804 [SAR 1:1 DAR 160:67], 23.98 fps, 23.98 tbr, 1k tbn, 180k tbc (default) Metadata: BPS-eng : 5083069 DURATION-eng : 02:49:03.926000000 NUMBER_OF_FRAMES-eng: 243211 NUMBER_OF_BYTES-eng: 6445285513 _STATISTICS_WRITING_APP-eng: mkvmerge v31.0.0 ('Dolores In A Shoestand') 64-bit _STATISTICS_WRITING_DATE_UTC-eng: 2019-03-11 19:34:49 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:1(eng): Audio: dts (DTS-HD MA), 48000 Hz, 5.1(side), s32p (24 bit) (default) Metadata: title : Surround BPS-eng : 3693052 DURATION-eng : 02:49:03.936000000 NUMBER_OF_FRAMES-eng: 950994 NUMBER_OF_BYTES-eng: 4682760972 _STATISTICS_WRITING_APP-eng: mkvmerge v31.0.0 ('Dolores In A Shoestand') 64-bit _STATISTICS_WRITING_DATE_UTC-eng: 2019-03-11 19:34:49 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:2(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s Metadata: title : Surround BPS-eng : 640000 DURATION-eng : 02:49:03.936000000 NUMBER_OF_FRAMES-eng: 316998 NUMBER_OF_BYTES-eng: 811514880 _STATISTICS_WRITING_APP-eng: mkvmerge v31.0.0 ('Dolores In A Shoestand') 64-bit _STATISTICS_WRITING_DATE_UTC-eng: 2019-03-11 19:34:49 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:3(ger): Audio: dts (DTS-HD MA), 48000 Hz, 5.1(side), s32p (24 bit) Metadata: title : Surround BPS-eng : 3703564 DURATION-eng : 02:49:03.936000000 NUMBER_OF_FRAMES-eng: 950994 NUMBER_OF_BYTES-eng: 4696090480 _STATISTICS_WRITING_APP-eng: mkvmerge v31.0.0 ('Dolores In A Shoestand') 64-bit _STATISTICS_WRITING_DATE_UTC-eng: 2019-03-11 19:34:49 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:4(eng): Subtitle: hdmv_pgs_subtitle Metadata: BPS-eng : 33817 DURATION-eng : 02:47:46.619000000 NUMBER_OF_FRAMES-eng: 4194 NUMBER_OF_BYTES-eng: 42553288 _STATISTICS_WRITING_APP-eng: mkvmerge v31.0.0 ('Dolores In A Shoestand') 64-bit _STATISTICS_WRITING_DATE_UTC-eng: 2019-03-11 19:34:49 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:5(ger): Subtitle: hdmv_pgs_subtitle Metadata: BPS-eng : 38389 DURATION-eng : 02:47:46.619000000 NUMBER_OF_FRAMES-eng: 4192 NUMBER_OF_BYTES-eng: 48306779 _STATISTICS_WRITING_APP-eng: mkvmerge v31.0.0 ('Dolores In A Shoestand') 64-bit _STATISTICS_WRITING_DATE_UTC-eng: 2019-03-11 19:34:49 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:3 -> #0:1 (dts (dca) -> mp3 (libmp3lame)) Press [q] to stop, [?] for help [segment @ 0x82df80] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/873de9408f96fcd33fa764fb9018ef5b34.ts' for writing Output #0, segment, to '/var/packages/EmbyServer/target/var/transcoding-temp/873de9408f96fcd33fa764fb9018ef5b%d.ts': Metadata: encoder : Lavf58.12.100 Stream #0:0: Video: h264 (High), yuv420p(tv, bt709, progressive), 1920x804 [SAR 1:1 DAR 160:67], q=2-31, 23.98 fps, 23.98 tbr, 90k tbn, 1k tbc (default) Stream #0:1(ger): Audio: mp3 (libmp3lame), 48000 Hz, stereo, fltp (24 bit), 128 kb/s (default) Metadata: encoder : Lavc58.18.100 libmp3lame [segment @ 0x82df80] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/873de9408f96fcd33fa764fb9018ef5b.m3u8.tmp' for writing frame= 66 fps=0.0 q=-1.0 Lsize=N/A time=00:03:23.95 bitrate=N/A speed= 596x video:1689kB audio:45kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
CChris 59 Posted March 12, 2019 Author Posted March 12, 2019 OK, I found the next movie with the same issue for the DTS Audio Track... not sure, if this is somehow related to my encodings or not :-/
Luke 42242 Posted March 13, 2019 Posted March 13, 2019 You can always try a different browser and see how that compares.
CChris 59 Posted March 17, 2019 Author Posted March 17, 2019 Hi Luke, Sorry for the late reply. It seems that the sound issues only appear in Google Chrome.I have noticed this issue in several movies now... also, I have tested one movie (mentioned above - interstellar) in Firefox and I was not able to hear anything strange in the audio...
CChris 59 Posted April 1, 2019 Author Posted April 1, 2019 (edited) Hi, yes. With Chrome I still have this issue on some movie. With Firefox Eversthing seems to be fine. Edited April 1, 2019 by CChris
