NNate 10 Posted May 10, 2014 Posted May 10, 2014 I have my MPC-HC setup matching what is described in this guide: http://www.avsforum.com/t/1357375/advanced-mpc-hc-setup-guide XYSubfilter is installed and my subtitles work as expected when opening an mkv file through MPC-HC. Right clicking and choosing "filters" in MPC-HC shows me XYSubfilter is running as I expect. When I launch a movie in MBC, it launches MPC-HC, but my subtitles don't work. The XYSubfilter does not show up in the "filters" view. Why does it not work when Media Browser Classic launches MPC-HC for me? I've read through other threads that talk about using xy-VSFilter, but why should I need this too when everything works fine directly through MPC-HC? Thanks!
ebr 16334 Posted May 10, 2014 Posted May 10, 2014 I'm not sure. Perhaps there is a command line option that needs to be set? You can edit the command line that is used when opening MPC in the external player setup in the configurator.
NNate 10 Posted May 10, 2014 Author Posted May 10, 2014 Hmmm, I took a look at my logs. It looks like the path substitution I put in to get Xbmc Metadata Server and OpenElec to behave is interfering with MB on Windows. Here's a snippet of interest 2014-05-09 06:31:45.2361,Info,,Sending Http Get to http://192.168.1.125:8096/mediabrowser/Users/18ca55ff-9077-8a66-5ee3-c3d2f2819c91/Items/60532264-2476-d04d-5267-62f073ab1d0d/Intros?format=Json,46,Worker thread for Play Action 2014-05-09 06:31:45.2449,Info,,Unable to access smb://kooistraserver/Movies/Thor The Dark World (2013)/Thor The Dark World (2013).mkv. Will try to stream.,46,Worker thread for Play Action 2014-05-09 06:31:45.2449,Debug,,Looking for audio stream in eng,46,Worker thread for Play Action 2014-05-09 06:31:45.2449,Debug,,Requesting audio stream #0,46,Worker thread for Play Action 2014-05-09 06:31:45.2469,Info,,MPC-HC playing Thor: The Dark World,46,Worker thread for Play Action 2014-05-09 06:31:45.2488,Debug,,Sending Http Post to http://192.168.1.125:8096/mediabrowser/Users/18ca55ff-9077-8a66-5ee3-c3d2f2819c91/PlayingItems/60532264-2476-d04d-5267-62f073ab1d0d?CanSeek=True&QueueableMediaTypes=&format=Json,46,Worker thread for Play Action 2014-05-09 06:31:45.2556,Info,,Starting command line C:\Program Files (x86)\MPC-HC\mpc-hc.exe "http://192.168.1.125:8096/mediabrowser/Videos/60532264-2476-d04d-5267-62f073ab1d0d/stream.wmv?VideoCodec=Wmv&VideoBitRate=5000000&MaxWidth=1280&AudioStreamIndex=0&audiochannels=2&AudioBitRate=128000" /play /close /fullscreen /start 0,46,Worker thread for Play Action If I understand this correctly, it's trying to stream instead of just load up the file to play. How do I have path substitution in place to work for Xbmc Metadata Saver for OpenElec, but not interfere with other functions?
ebr 16334 Posted May 10, 2014 Posted May 10, 2014 Correct, it is streaming from the server. I guess the good news is that you couldn't tell it was streaming . I'm not sure about the other issue. The path substitution feature is specifically designed to avoid the problem you have now. You used it instead to make the file references work in a linux file system directly?
NNate 10 Posted May 10, 2014 Author Posted May 10, 2014 (edited) Correct, it is streaming from the server. I guess the good news is that you couldn't tell it was streaming . I'm not sure about the other issue. The path substitution feature is specifically designed to avoid the problem you have now. You used it instead to make the file references work in a linux file system directly? Well, I did notice some artifacts - especially in dark scenes. I just assumed it was bad Blu-ray mastering... But on the whole, the streaming seemed to be working very well . Yeah, in order tor the Xbmc Metadata Saver Plugin to write the appropriate paths for Xbmc in Linux to understand (in the XBMC .nfo file), I had to use path substitution. This is so the proper fanarts, poster, actor thumbnails work in the XBMC interface. It used to be that this was limited to just the plugin, but then it got moved into the entire MB3 Server. Edited May 10, 2014 by NNate
ebr 16334 Posted May 10, 2014 Posted May 10, 2014 @@Luke - I guess we need separate settings for the saver vs. playback from clients.
