more options for AutoBoxSet / Collections
Hi,
Would it be possible to add an option to the AutoBoxSet-Plugin, which libraries the Plugin should use for generating the Box Sets?
e.g. havin two Movie-Libraries, the AutoBoxSet will generate the collections on movies in both libraries.
But I would like to tell the plugin, that only one specific library should be used.
Movies from the second library won't be added to collections, and even if I have movies from a collection in both libraries, autoBox Set should only generate a collection from the movies in the selected library.
  • Like 1
Hi, yes it makes sense. Thanks.
  • Like 1
  • 1 year later...
This will be in Emby Server 4.6.
