Leyst 2 Posted March 11, 2019 Posted March 11, 2019 (edited) Hello, When I connect to emby on my iphone through wifi it works, when I try to connect through 4G I get a connection error. Is there a way to fix this? I also keep getting the "purchase premiere" when I want to watch something on my phone on my wifi.. and i have premiere.. Edited March 11, 2019 by Leyst
Luke 42243 Posted March 12, 2019 Posted March 12, 2019 HI, when you're connecting remotely, is this over http, or https? Regarding premiere status, did you purchase premiere using the iOS app, or on our website?
Leyst 2 Posted March 13, 2019 Author Posted March 13, 2019 (edited) Hi Luke, It works when i connect through the browser, but it dosen't work through the app. I purshased it through the website. (It's even asking me on windows to buy premiere) Edited March 13, 2019 by Leyst
Luke 42243 Posted March 13, 2019 Posted March 13, 2019 HI, when you're connecting remotely, is this over http, or https?
Leyst 2 Posted March 14, 2019 Author Posted March 14, 2019 (edited) When I connect Https it works, but over the app it dosent. But it keeps asking me to buy premiere even when I use the Theater on windows 10, and my samsung smart tv Edited March 14, 2019 by Leyst
Luke 42243 Posted March 16, 2019 Posted March 16, 2019 What kind of ssl certificate? You will need to be using a certificate that Apple devices do not reject. Unlike the browser the app has no way to override this.
Leyst 2 Posted March 16, 2019 Author Posted March 16, 2019 What kind of ssl certificate? You will need to be using a certificate that Apple devices do not reject. Unlike the browser the app has no way to override this. I'm using the Emby app from the app store, not sure how I can check the ssl certificate. But it keeps asking me to activate on my samsung tv, and on my windows ect. It only works through safari on my phone.
Luke 42243 Posted March 16, 2019 Posted March 16, 2019 I mean what kind of SSL certificate is on your Emby Server?
Leyst 2 Posted March 16, 2019 Author Posted March 16, 2019 (edited) I mean what kind of SSL certificate is on your Emby Server? Is it under Expert -> Advanced? if it is its empty The samsung and windows asks for premium on local wifi Edited March 16, 2019 by Leyst
Luke 42243 Posted March 17, 2019 Posted March 17, 2019 But earlier you said this: When I connect Https it works Are you sure it's https?
Leyst 2 Posted March 17, 2019 Author Posted March 17, 2019 (edited) But earlier you said this: Are you sure it's https? I am not sure if the apps are https. How can I check & force that? I tried looking at the forums, and dosent look like ive setup a https, and I have no idea how to do it. Cant seem to find a tutorial how to setup a emby https without a domain. but its not even working on my local network, it just asks me to upgrade to premium. Edited March 17, 2019 by Leyst
