BigSteve84 14 Posted March 11, 2019 Posted March 11, 2019 Hi, I've tried at least 3 IPTV m3u's and tried on the shield and then my phone but the same problem arises theres no guide data even when I use my schedules direct login and or emby direct guide, no data shows in the epg, theres nothing showing up on programmes, theres nothing on map channels, nothing shows on the home screen for 'whats on live tv' but the channels show up on the channels section ? Also I've got a log but not sure what personal info I need to cover up?
arche 177 Posted March 11, 2019 Posted March 11, 2019 Also I've got a log but not sure what personal info I need to cover up? You can pm @@Luke and/or @@ebr your log files if you don't feel comfortable posting.
Carlo 4561 Posted March 12, 2019 Posted March 12, 2019 Hi, I've tried at least 3 IPTV m3u's and tried on the shield and then my phone but the same problem arises theres no guide data even when I use my schedules direct login and or emby direct guide, no data shows in the epg, theres nothing showing up on programmes, theres nothing on map channels, nothing shows on the home screen for 'whats on live tv' but the channels show up on the channels section ? Also I've got a log but not sure what personal info I need to cover up? If the channels are showing up but no program info and you have imported the EPG (SD or built in) then it sounds like you haven't mapped each and every channel source (from iptv) to appropriate EPG source which is needed for some IPTV feeds as they use IDs that aren't standard to the guide sources. If you want another set of eyes to look over what you're doing, shoot me a PM and we can setup a teamviewer session and I'll remotely help you.
dragao20 3 Posted March 21, 2019 Posted March 21, 2019 Bonjour, For logos i updated emby is after that worked. What it uses XML file for TV guide ?
Luke 42237 Posted March 23, 2019 Posted March 23, 2019 Bonjour, For logos i updated emby is after that worked. What it uses XML file for TV guide ? Hi there @@dragao20, do you have an xml tv guide provider?
Dhop84 1 Posted April 6, 2019 Posted April 6, 2019 I'm having this issue with recording live tv, as soon as the show starts it stops recording, I've got a log if it's ok to pm you @@Luke ?
