kanipek 230 Posted March 10, 2019 Posted March 10, 2019 I added a <sorttitle></sorttitle> field in the NFO's of my Marvel collection but I can't seem to find where/what to change to tell Emby to use the sort tile in the NFO files. Is this still supported? If so where/how? Thanks
Luke 42217 Posted March 10, 2019 Posted March 10, 2019 How did you do this? Emby does not use nfo files for collections.
kanipek 230 Posted March 10, 2019 Author Posted March 10, 2019 How did you do this? Emby does not use nfo files for collections. The NFO's for each of the movie's in the collection
kanipek 230 Posted March 10, 2019 Author Posted March 10, 2019 Would I add "<DisplayOrder>SortName</DisplayOrder>" to the collection XML?
Solution Happy2Play 9806 Posted March 10, 2019 Solution Posted March 10, 2019 Are you referring to Display Order (Sort Name/Release date)? edit metadata on the collection itself 1
kanipek 230 Posted March 10, 2019 Author Posted March 10, 2019 Are you referring to Display Order (Sort Name/Release date)? edit metadata on the collection itself That did it. Thanks Happy.
Luke 42217 Posted March 10, 2019 Posted March 10, 2019 I would instead use editing functions that are built into Emby.
