schmitty 66 Posted March 9, 2019 Posted March 9, 2019 Hi, I think there is an across-the-board change that needs to be with all Emby player apps. 1) Remove codec and channel layout info from Audio Language drop downs, only display the Language 2) Display Video and Audio codec info (including definition, channel layout and resolution) in a similar fashion to parental rating/closed captions mark. 3) Offer a setting (probably in Display settings) to display Media Info as icons (like CoverArt does) instead.
Luke 42246 Posted March 9, 2019 Posted March 9, 2019 For #1, then you can't tell the difference between a dts track and a stereo track.
ebr 16338 Posted March 9, 2019 Posted March 9, 2019 Yeah, due to popular demand, we've actually just done the opposite of this...
schmitty 66 Posted March 10, 2019 Author Posted March 10, 2019 (edited) For #1, then you can't tell the difference between a dts track and a stereo track. That would be where #2 comes into play. Or, at the very least... display the full language name, codec profile (currently codec), and layout (display stereo as 2.0) in the dropdown. Nb: I think TRUEHD needs to be displayed as TrueHD, for visual continuity. English - DTS-HD MA 7.1 English: DTS-HD MA 7.1 Edited March 10, 2019 by schmitty
