avinashp 0 Posted March 8, 2019 Posted March 8, 2019 Hi, I am not sure if this has been answered already, I am having issues with cinema mode not playing trailers before the main feature. As of now, I installed both Cinema mode and Trailers plugins and restarted the server. I set the cinema mode to play 3 trailers. But, I don't get anything when I play movies in my library. Am I missing something please? Do I need to manually download trailers? etc. Please see attached snapshots for both Cinema mode and Trailer settings. Thank you!
Luke 42219 Posted March 10, 2019 Posted March 10, 2019 Hi, this will be resolved in Emby Server 4.1. Thanks. 1
j4jacks 0 Posted March 11, 2019 Posted March 11, 2019 Hi, this will be resolved in Emby Server 4.1. Thanks. Great as the same thing is happening to me and I couldn't figure it out! Looking forward to the update
nagetech 70 Posted April 20, 2019 Posted April 20, 2019 Just wanted to throw my hat in. Trailers haven't played for me in a bit either
Luke 42219 Posted April 20, 2019 Posted April 20, 2019 Hi, can you please go over an example? thanks.
crusher11 1138 Posted April 20, 2019 Posted April 20, 2019 How are trailers selected? I have 40 trailers on my server, and I keep getting the same three or four every time.
Happy2Play 9806 Posted April 20, 2019 Posted April 20, 2019 Hi, can you please go over an example? thanks. What do you need? Cinema mode enabled, options don't appear to matter. Hit play on a movie and it only played local trailers. If no local trailers are available then movie just starts. I have seen no change since the report of the issue awhile ago. Same discussion in other topic.
Luke 42219 Posted April 20, 2019 Posted April 20, 2019 How are trailers selected? I have 40 trailers on my server, and I keep getting the same three or four every time. By similarity, so genres and other metadata fields such as that.
BuddahKat 17 Posted April 21, 2019 Posted April 21, 2019 I noticed a new version of Cinema Mode was released, however it doesnt seem to have fixed the issue. I have my settings set for 3 new / upcoming trailers, no local files, but when I tried a movie tonight it played two files from one of my 'extras' folder, no internet trailers, and then played my movie. There are plenty of new / recently released trailers in the 'Trailers' section the movies view so doesnt seem to be an issue with the plugin.
nagetech 70 Posted April 21, 2019 Posted April 21, 2019 Same here. Just saw the updated cinema mode. I have it setup to play 2 trailers before any movie. I have no local trailers at all. Tested playing about 11 movies and none of them had a trailer play first
Luke 42219 Posted April 22, 2019 Posted April 22, 2019 Make sure the user who is playing is granted access to the trailer channel, and doesn't have any parental control restrictions that would prevent them from being able to see the trailers.
Happy2Play 9806 Posted April 22, 2019 Posted April 22, 2019 None of my users have parental controls and have any access restrictions.
brenthf 0 Posted April 22, 2019 Posted April 22, 2019 Same here. Can see plenty of trailers in trailer library but not a single one played. Server version 4.1.0.26
nagetech 70 Posted April 23, 2019 Posted April 23, 2019 Just tossing an update, I saw today the plugins were updated. I tested 17 movies just hitting play to see if it would play a trailer first, but nothing
Happy2Play 9806 Posted April 23, 2019 Posted April 23, 2019 This is actually working in the beta server 4.2.0.1 and will be backported into 4.1.1.0 as mentioned in the other topic.
j4jacks 0 Posted May 10, 2019 Posted May 10, 2019 4.1.1.0 fixed it for me. Trailers are playing fine now. Thanks!
