EduardoSantos 40 Posted March 8, 2019 Posted March 8, 2019 Would be great to have a 10 or 30 seconds instant replay on Emby...
ebr 16338 Posted March 8, 2019 Posted March 8, 2019 Hi. Can you please explain exactly what you mean? We already have the ability to skip back in all the apps.
EduardoSantos 40 Posted March 10, 2019 Author Posted March 10, 2019 Hi. Can you please explain exactly what you mean? We already have the ability to skip back in all the apps. I mean a simple button that allows a 30 or 10 second back skipping like there is on NetFlix. I know there is a slider that can be used to skip back on every app. This is, though, not pratical when you just want to see the same 30 sec like when you lost a scene. The slider tends to be difficult to use on short intervals.
ebr 16338 Posted March 10, 2019 Posted March 10, 2019 Hi. What app are you using? They all have a skip back of some sort. I believe every app has a button on the OSD to skip back 10 seconds. Also, on the touch apps (Android mobile, web) you can double-tap the left side of the screen to skip back.
EduardoSantos 40 Posted April 3, 2019 Author Posted April 3, 2019 I am using Emby`s Android app to cast to a Chromecast. I can only find two buttons (next and previous). They are shown both on Emby`s app interface and on the lock screen. Both of them do nothing when playing a movie. When playing a series episode they allow me to go to the previous and next episode. Is there any means to rewind 10 or 30 sec. on the Android app when casting to Chromecast?
EduardoSantos 40 Posted April 3, 2019 Author Posted April 3, 2019 @@Luke, Yes, this occurs in portrait mode.Following your question I tried in landscape mode.Thanks: the skip forward and rew will show on landscape mode.Took some images
Luke 42246 Posted April 3, 2019 Posted April 3, 2019 Right ok, they are hidden just due to the amount of space available on the smaller horizontal resolution.
