groenator 13 Posted March 6, 2019 Posted March 6, 2019 I deployed my emby server inside a Docker container that runs on Ubuntu 18.4 LTS. I noticed that when the refresh guide is updating the CPU usage goes nuts. It reaches 100% usage. I am using the latest version of Emby Server. Is there a way to reduce CPU usage? Below is my Top command output. top - 21:19:58 up 22:39, 1 user, load average: 1.02, 1.03, 1.00 Tasks: 252 total, 1 running, 159 sleeping, 0 stopped, 0 zombie %Cpu0 : 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st %Cpu1 : 0.3 us, 0.0 sy, 0.0 ni, 99.7 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st %Cpu2 : 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st %Cpu3 : 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st %Cpu4 : 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st %Cpu5 : 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st %Cpu6 : 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st %Cpu7 : 0.3 us, 0.0 sy, 0.0 ni, 99.7 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st %Cpu8 : 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st %Cpu9 : 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st %Cpu10 : 97.7 us, 2.0 sy, 0.0 ni, 0.0 id, 0.3 wa, 0.0 hi, 0.0 si, 0.0 st %Cpu11 : 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st KiB Mem : 8067192 total, 1080664 free, 2593556 used, 4392972 buff/cache KiB Swap: 0 total, 0 free, 0 used. 5145180 avail Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 21055 root 20 0 5947984 467248 48200 S 100.0 5.8 212:32.00 /system/EmbyServer -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 1227 root 20 0 1358256 64748 35916 S 0.3 0.8 3:58.60 dockerd -G docker --exec-root=/var/snap/docker/321/run/docker --data-root=/var/snap/docker/common/var-lib-docker --pidfile=/var/snap/d+ 13625 root 20 0 1795872 347828 31720 S 0.3 4.3 30:54.63 mono --debug /app/Lidarr.exe --nobrowser --data=/config/app 21482 grosub 20 0 44676 4132 3352 R 0.3 0.1 0:01.24 top
Luke 42243 Posted March 6, 2019 Posted March 6, 2019 Hi there, can you please attach the emby server log? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
groenator 13 Posted March 6, 2019 Author Posted March 6, 2019 (edited) Seems that is not only when refreshing the guide, but it is also happening when downloading subtitles, updating the library. Basically, every time when a scheduled job starts. Edited March 6, 2019 by groenator
Luke 42243 Posted March 7, 2019 Posted March 7, 2019 Please try removing the following plugins, then restarting the server and see if this helps: Auto Organize 1.3.7.0 CoverArt 4.0.93.0 Statistics 2.0.8.0 Thanks.
groenator 13 Posted March 7, 2019 Author Posted March 7, 2019 Cool, I will do that. Would I be able to use the plugin again?
groenator 13 Posted March 7, 2019 Author Posted March 7, 2019 One quick question: is emby single threaded application or not?
groenator 13 Posted March 7, 2019 Author Posted March 7, 2019 Hi, Nothing changed, I removed the plugins, restarted the container. I started to refresh the guide, it's still using one CPU. Does it make any difference that the emby settings were imported from my qnap? I migrated the container from qnap to Ubuntu.
groenator 13 Posted March 7, 2019 Author Posted March 7, 2019 I'll try building a new emby server with clean settings.
groenator 13 Posted March 7, 2019 Author Posted March 7, 2019 These logs are from the new server I configured now. Emby is still using one CPU with the new server. If you want me to send you the debug logs let me know. Regards,
Luke 42243 Posted March 8, 2019 Posted March 8, 2019 So what happens is the guide data gets read multiple times, once for each channel. We will make this more efficient in a future update. thanks.
groenator 13 Posted April 1, 2019 Author Posted April 1, 2019 The refreshing of the guide is really testing my patient ... Any idea when this fix will be implemented? Is there a bug open already for it? I dont to be dramatic, but hearing the fan spinning like crazy all the time is a bit upsetting..
Luke 42243 Posted April 3, 2019 Posted April 3, 2019 It's going to come with the upcoming revamp of channel management. Thanks.
groenator 13 Posted May 19, 2019 Author Posted May 19, 2019 So what happens is the guide data gets read multiple times, once for each channel. We will make this more efficient in a future update. thanks. Any news when this fix will be implemented?
Nikoh77 0 Posted April 16, 2022 Posted April 16, 2022 (edited) hello guys, some news? My server is about to explode every time autoupdate the epg guide.... @Luke This is a serious problem, yesterday proxmox completely crashed with all vm's Edited April 16, 2022 by Nikoh77
Luke 42243 Posted April 16, 2022 Posted April 16, 2022 57 minutes ago, Nikoh77 said: hello guys, some news? My server is about to explode every time autoupdate the epg guide.... @Luke This is a serious problem, yesterday proxmox completely crashed with all vm's @Nikoh77 please attach the emby server log from when this happened. Thanks.
EODCrafter 181 Posted April 16, 2022 Posted April 16, 2022 (edited) 5 hours ago, Nikoh77 said: hello guys, some news? My server is about to explode every time autoupdate the epg guide.... @Luke This is a serious problem, yesterday proxmox completely crashed with all vm's Interesting, mine barely ticks above 3% usage on all four. EDIT: Whoops...maybe not...... Settled down after guide refresh done, does seem a little excessive for simple xml file refresh..... Edited April 16, 2022 by EODCrafter
Nikoh77 0 Posted April 16, 2022 Posted April 16, 2022 @Luke i always see this command (on htop) which has many active processes and which consumes a lot of cpu time and mem during updating epg guide, is this normal? Quote /opt/emby-server/system/EmbyServer.dll -programdata /home/nikoh/embymediaserver -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb
