bingetv281 0 Posted March 6, 2019 Posted March 6, 2019 Hi I just moved my EMBY server to a different vps but when I did the restore it added all the libraries twice! Lol Now there's twice as many sections....please help
Luke 42246 Posted March 6, 2019 Posted March 6, 2019 Hi there, where exactly are they duplicated? Thanks.
bingetv281 0 Posted March 7, 2019 Author Posted March 7, 2019 They are duplicated in my media and latest media sections.
Luke 42246 Posted March 7, 2019 Posted March 7, 2019 Ok, please remove the one from Emby library setup, then run two full library scans. This should clear the duplicates. Then you can add the library back, and when you do, make sure to only click OK once on the add library dialog. Please let us know if this helps. Thanks.
