abescalamis 88 Posted March 6, 2019 Posted March 6, 2019 (edited) I have an issue that I have not been able to fix; there is a duplicate entry of the recorded shows, even if I just select one in the User --->Access, then when I go back to the setting it auto selects both. I have this issue since I started to use Emby, I think is specific to the Synology NAS Emby but don't know. Edited March 6, 2019 by abescalamis
Solution abescalamis 88 Posted March 6, 2019 Author Solution Posted March 6, 2019 (edited) I was able to fix it, I gave the "series recording path" and the "Default recording path" the location of parent folder, let the library scan bla, bla. after I re entered the paths like in the second picture in the post above, and that deleted the extra entry. all good, and thank you. Edited March 6, 2019 by abescalamis
Luke 42245 Posted March 7, 2019 Posted March 7, 2019 Thanks for the feedback. We need to rework these settings and make them easier.
