Seshead 0 Posted March 6, 2019 Posted March 6, 2019 I have had the scan up for three days and its only sitting at 87.6% when I switch to library screen its shows 90% complete. Files are being scanned out of a DS212J is this a synology or emby issue? I have attached logs. Please help! this is driving me nuts! Thanks in advance Log emby.txt
Luke 42242 Posted March 6, 2019 Posted March 6, 2019 Hi, the first scan is taking a long time because it is probing your files for media info. Subsequent scans will be much faster. Thanks.
Seshead 0 Posted March 6, 2019 Author Posted March 6, 2019 Thanks Luke for your prompt response. Is there any way to do it faster or im stuck as is?
Luke 42242 Posted March 6, 2019 Posted March 6, 2019 You'll just need to give it time and allow it to finish. thanks.
solabc16 379 Posted March 11, 2019 Posted March 11, 2019 Hello @@Seshead The DS212J is a single core ARMv5 machine, so it is limited in how much raw horsepower it can bring to the table. However, if you can get the scan to the end, it should be able to provide a reasonable service. The scenarios in which it is practical are somewhat limited on the older machines, but we have a number of users putting them to good use for specific scenarios like this. (e.g. Music libraries) Let us know how you get on and if you need any further assistance. Best - James
