Pain 13 Posted March 4, 2019 Posted March 4, 2019 (edited) Not sure if this is server or app related. It seems on live TV when recording a series and only wanting to record new becomes a problem when the guide displays repeat when its not. HDHomerun channels seem to work just fine but IPTV does not. However I see a couple channels like ESPN seems to show it as new rather then repeat. Using Emby Guide data with m3u Server is a Synology DS218+ Apps are FireTV and Nividia Shield. Thanks Pain Edited March 4, 2019 by Pain
Pain 13 Posted March 4, 2019 Author Posted March 4, 2019 (edited) @@Luke If I set a series to record only new it will skip the show because it says its repeat when its not. Edited March 4, 2019 by Pain
Luke 42217 Posted March 5, 2019 Posted March 5, 2019 Can you please go over a specific example? Thanks.
Pain 13 Posted March 6, 2019 Author Posted March 6, 2019 I think I have it figured out. I was using a xmltv with Emby guide data and I think the issue was the xmltv guide date was not right. I have not noticed a issue yet myself, this is coming from other family members. I am now using Emby data for all my guide and seems to be working just fine. Thanks Pain
