blakkmaan 0 Posted March 4, 2019 Posted March 4, 2019 (edited) Hey, i got a Problem using DLNA with latest Emby Server for DSM on my 218+. I got a LG TV and the TV cant find the DLNA Server (i should select/see it through the Input Section). But on my devices i can select the TV for DLNA Play to. So for the server the TV is visible but the TV itself cant reach Emby through DLNA. If i select a media source and want to play it through DLNA Play to simply nothing happens. i got another machine with emby which i powered up and through this one everything is working well (simple NUC with Ubuntu and Emby) ------ SOLUTION ------- Cut off my Repeater as the TV was on cable connected to it. If i let the TV Connect straight via WIFI to my router everything is working again. i think somehow it interrupted the communication.. Edited March 4, 2019 by blakkmaan
Luke 42242 Posted March 4, 2019 Posted March 4, 2019 Hi there, can you please attach the complete emby server log? thanks !
blakkmaan 0 Posted March 4, 2019 Author Posted March 4, 2019 (edited) --- edited see 1st post --- Edited March 4, 2019 by blakkmaan
