Luke 42287 Posted December 16, 2022 Posted December 16, 2022 11 hours ago, bbandreasb said: I know it's a fork. But i mainly was referring to the old open project MediaBrowser. But i love being able to fix things myself. I have been using Emby Premiere as well, to support you guys, and know that it takes hours to fix bugs and make new features But i have to say i still wish Emby was a complete Open Source project. Btw is there still parts of Emby that is open source which developers can make new stuff for? And sorry for putting it on this thread. Hi, yes we have a lot of open source plugins. 1
gh0stwriter 3 Posted January 11, 2023 Posted January 11, 2023 Having what appears to be the same issue. I have 1 emby server running in a jail on Truenas Core.... works fine and the premiere status is recognized (except encoding since well FreeBSD I might be able to get it working at some point though). I also have a Teramaster F2-211 I loaded the emby plugin from their app installer... and it appears to work, except saving my lifetime premiere key to it doesn't appear to do anything... I can ping mb3admin.com from the nas command line so I don't think there is a connectivity issue or and can't think of anything else on my end I even set them up from the same computer and browser.
Happy2Play 9814 Posted January 11, 2023 Posted January 11, 2023 @gh0stwriter Can you provider a server log. How to Report a Problem
gh0stwriter 3 Posted January 11, 2023 Posted January 11, 2023 This is after enabling debug loglevel, removing key restarting, then adding the key back. I then uploaded the latest log. embyserver.txt
ebr 16354 Posted January 11, 2023 Posted January 11, 2023 Hi. Your server is validating properly. Make sure nothing in your browser is blocking - e.g. Privacy Badger.
gh0stwriter 3 Posted January 11, 2023 Posted January 11, 2023 I only have an Ublock Origin in Firefox (and I tried turning that and the built in tracking protection off and it continued not to work). I never turned these off for my first server and its still working.
gh0stwriter 3 Posted January 11, 2023 Posted January 11, 2023 Also tried with google chrome (and competely clean slate install of chrome I don't usually use)... still no dice.
ebr 16354 Posted January 11, 2023 Posted January 11, 2023 44 minutes ago, gh0stwriter said: still no dice Exactly what is happening? Are there any errors in the browser console? (ctl-shift-c in Chrome)
gh0stwriter 3 Posted January 11, 2023 Posted January 11, 2023 (edited) So I think I have it figured out..... when opening Emby from the Teranas desktop the link it uses is https://192.168.4.251:5443/emby/web/index.html#!/home When I click on the link from the emby settings page http://192.168.4.251:8096/web/index.html#!/home It works perfect... so not sure why but the ports are setup weird not sure why. Not sure why 5443 even works (perhaps this is an NGINX proxies port or something)??? Also I manually updated to the beta (deleting all the files in the emby folder and isntalling works). Edited January 11, 2023 by gh0stwriter
Luke 42287 Posted January 11, 2023 Posted January 11, 2023 Hmm, 5443? What link exactly is that? Can you show a screenshot? Thanks.
Carlo 4561 Posted January 12, 2023 Posted January 12, 2023 16 hours ago, gh0stwriter said: So I think I have it figured out..... when opening Emby from the Teranas desktop the link it uses is https://192.168.4.251:5443/emby/web/index.html#!/home When I click on the link from the emby settings page http://192.168.4.251:8096/web/index.html#!/home It works perfect... so not sure why but the ports are setup weird not sure why. Not sure why 5443 even works (perhaps this is an NGINX proxies port or something)??? Also I manually updated to the beta (deleting all the files in the emby folder and isntalling works). Port 5443 is the well-known secured Pearson port used by spss services. SPSS stands for “Statistical Package for the Social Sciences”. It is an IBM tool first launched in 1968. Seems more like a coincidence. Being that the port number contains 443 it sounds like some kinds of forwarding/proxy being used. If you have NGINX installed (default or added) you may want to check the configuration to see if it's using 5443.
gh0stwriter 3 Posted January 13, 2023 Posted January 13, 2023 On 1/12/2023 at 5:15 AM, cayars said: Port 5443 is the well-known secured Pearson port used by spss services. SPSS stands for “Statistical Package for the Social Sciences”. It is an IBM tool first launched in 1968. Seems more like a coincidence. Being that the port number contains 443 it sounds like some kinds of forwarding/proxy being used. If you have NGINX installed (default or added) you may want to check the configuration to see if it's using 5443. This has nothing to do at all with SPSS (which ironically I am aware of having used R quite a bit in college) This is just the default TOS NGINX proxy configuration for Emby being bleeped up. Every package in TOS5 appears to get redirected through NGINX from the icon in the TOS5 desktop.
gh0stwriter 3 Posted January 13, 2023 Posted January 13, 2023 (edited) On 1/11/2023 at 3:00 PM, Luke said: Hmm, 5443? What link exactly is that? Can you show a screenshot? Thanks. If you click on that link on the TOS5 desktop it by default goes to that port... you can of course just use the correct port and it works as intended. But for whatever reason... TOS5 is proxying Emby via NGINX and this breaks the license check apparently. Also if you happen to stop the emby service on TOS5 you of course get an NGINX page saying that its unavailable etc... Edited January 13, 2023 by gh0stwriter
bbandreasb 0 Posted January 14, 2023 Posted January 14, 2023 On 1/11/2023 at 6:56 PM, gh0stwriter said: So I think I have it figured out..... when opening Emby from the Teranas desktop the link it uses is https://192.168.4.251:5443/emby/web/index.html#!/home When I click on the link from the emby settings page http://192.168.4.251:8096/web/index.html#!/home It works perfect... so not sure why but the ports are setup weird not sure why. Not sure why 5443 even works (perhaps this is an NGINX proxies port or something)??? Also I manually updated to the beta (deleting all the files in the emby folder and isntalling works). This sounds like the Emby installation previously has been used with the port 5443. I've myself have seen this on my end, since i use local webservers to develop web apps. Then when i saw that the port was used by Emby afterwards, i changed it within Emby, then i got two different links in the browser. Not sure if that's the exact same thing you got though.
gh0stwriter 3 Posted January 21, 2023 Posted January 21, 2023 On 1/13/2023 at 10:38 PM, bbandreasb said: This sounds like the Emby installation previously has been used with the port 5443. I've myself have seen this on my end, since i use local webservers to develop web apps. Then when i saw that the port was used by Emby afterwards, i changed it within Emby, then i got two different links in the browser. Not sure if that's the exact same thing you got though. It's not it's terramaster botching their configuration of the package. It's just the plain Emby install after installing it form the TOS package manager... the way they have the system setup is to proxy everything through NGINYX for no reason.
