dcol 177 Posted March 2, 2019 Posted March 2, 2019 Using the NextPVR plug-in with Emby none of the tags, such as New, Premiere, Repeat, Live, etc., are displayed in my Emby LiveTV guide as of version 4.x. They were there in the past. Everything else seems ok. Pulls in the recordings I set in NPVR. Just no tags. Tags show ok in NPVR. Is this a setting, or a bug?
Luke 42239 Posted March 3, 2019 Posted March 3, 2019 I'm not sure. It's possible the plugin may need to be updated.
dcol 177 Posted March 3, 2019 Author Posted March 3, 2019 (edited) I'm not sure. It's possible the plugin may need to be updated. I am currently on version 3.3.0.0. Is there an update available? Or who do I report that to, @@sub3? Edited March 3, 2019 by dcol
dcol 177 Posted March 3, 2019 Author Posted March 3, 2019 The current beta 4.1.0.10 and higher seems to fix the old recording issues. As soon as the changes are implemented in the stable release I can remove the NPVR plugin. Until then, I need to use the plugin to ensure stable recordings. So I would like to see the plugin updated.
dcol 177 Posted June 9, 2019 Author Posted June 9, 2019 (edited) I am now on NPVR version 4.2.4 and NPVR Emby plugin version 3.3.1.0 and the communication to the Emby NPVR plugin got worse. None of the labels are present, such as 'New', 'Repeat', 'Premeire' etc. The guide itself is present in Emby, but that's it. No Artwork when I look at scheduled recordings. I also cannot schedule a recording from the Emby guide, Just get spinning circle. How do you do a cleanup for NPVR in Emby ? I did try to uninstall and reinstall the plugin with no success if I try to do a scheduled recording all I get is a spinning circle and there are errors in the embyserver.txt log. See attached recording started at 11:12:09 Here is a short list of the error 2019-06-09 11:12:18.072 Error HttpServer: Error processing request *** Error Report *** Version: 4.1.1.0 Command line: C:\Emby\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///C:/Emby/system/System.Private.CoreLib.dll Processor count: 4 Program data path: C:\Emby\programdata Application directory: C:\Emby\system System.InvalidOperationException: System.InvalidOperationException: Operation is not valid due to the current state of the object. at Emby.Server.Implementations.Library.LibraryManager.ConvertImageToLocal(BaseItem item, ItemImageInfo image, Int32 imageIndex, CancellationToken cancellationToken) at Emby.Drawing.ImageProcessor.ProcessImage(ImageProcessingOptions options, CancellationToken cancellationToken) at MediaBrowser.Api.Images.ImageService.GetImage(ImageRequest request, Int64 itemId, BaseItem item, Boolean isHeadRequest) at Emby.Server.Implementations.Services.ServiceExecGeneral.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, ILogger logger, String operationName, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, String urlString, String host, String localPath, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2019-06-09 11:12:18.072 Info HttpServer: HTTP Response 500 to 192.168.100.2. Time: 12ms. http://192.168.100.95:8096/emby/Items/4718995/Images/Primary?maxHeight=200&tag=e7e2c306ce5453d52f8b09b70187d45c&quality=902019-06-09 11:12:19.376 Info HttpServer: HTTP GET http://192.168.100.95:8096/emby/LiveTv/Timers/Defaults?programId=4718995. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0 2019-06-09 11:12:19.377 Info App: [NextPvr] Start GetNewTimerDefault Async2019-06-09 11:12:19.377 Info HttpClient: GET http://localhost:8867/public/ScheduleService/Get/SchedSettingsObj?sid2ae824d228a14e4eb034a08e3972ae082019-06-09 11:12:19.386 Info HttpServer: HTTP Response 200 to 192.168.100.2. Time: 10ms. http://192.168.100.95:8096/emby/LiveTv/Timers/Defaults?programId=47189952019-06-09 11:12:19.395 Info HttpServer: HTTP POST http://192.168.100.95:8096/emby/LiveTv/Timers. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0 2019-06-09 11:12:19.459 Info App: [NextPvr] Start GetNewTimerDefault Async2019-06-09 11:12:19.459 Info HttpClient: GET http://localhost:8867/public/ScheduleService/Get/SchedSettingsObj?sid2ae824d228a14e4eb034a08e3972ae082019-06-09 11:12:19.473 Info App: [NextPvr] Start CreateTimer Async for ChannelId: 11088 & Name: How It's Made2019-06-09 11:12:19.475 Info App: [NextPvr] Start GetDefaultScheduleSettings2019-06-09 11:12:19.475 Info HttpClient: GET http://localhost:8867/public/ScheduleService/Get/SchedSettingsObj?sid=2ae824d228a14e4eb034a08e3972ae082019-06-09 11:12:19.489 Info HttpClient: POST http://localhost:8867/public/ScheduleService/Record?sid=2ae824d228a14e4eb034a08e3972ae08 2019-06-09 11:12:19.504 Error App: [NextPvr] CreateTimer async with exception: NotFound2019-06-09 11:12:19.506 Error HttpServer: Error processing request *** Error Report *** Version: 4.1.1.0 Command line: C:\Emby\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///C:/Emby/system/System.Private.CoreLib.dll Processor count: 4 Program data path: C:\Emby\programdata Application directory: C:\Emby\system MediaBrowser.Controller.LiveTv.LiveTvConflictException: MediaBrowser.Controller.LiveTv.LiveTvConflictException: Exception of type 'MediaBrowser.Controller.LiveTv.LiveTvConflictException' was thrown. at MediaBrowser.Plugins.NextPvr.LiveTvService.CreateTimerAsync(TimerInfo info, CancellationToken cancellationToken) at Emby.LiveTV.LiveTvManager.CreateTimer(TimerInfoDto timer, CancellationToken cancellationToken) at Emby.Server.Implementations.Services.ServiceExecGeneral.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, ILogger logger, String operationName, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, String urlString, String host, String localPath, CancellationToken cancellationToken) Source: MediaBrowser.Plugins.NextPvr TargetSite: Void MoveNext() embyserver.txt Edited June 9, 2019 by dcol
emveepee 133 Posted June 9, 2019 Posted June 9, 2019 (edited) Ignoring the art API for now the looping on 2019-06-09 11:10:11.788 Info App: [NextPvr] Start GetRecordings Async, retrieve all 'Pending', 'Inprogress' and 'Completed' recordings2019-06-09 11:10:11.788 Info HttpClient: POST http://localhost:8867/public/ManageService/Get/SortedFilteredList?sid=2ae824d228a14e4eb034a08e3972ae08 is the same thing I am seeing with v5. I asked for feedback on what I might be missing but I didn't hear anything yet so t is possible that there is an Emby bug. The plugin response to this call hasn't change for a long time. Your logs didn't show the Refresh Guide task run so no way of telling if you are in sync with NextPVR. I wrote a utility to ensure they stayed in sync but no one opted to even try it Martin Edited June 9, 2019 by emveepee
dcol 177 Posted June 9, 2019 Author Posted June 9, 2019 Just started the refresh guide. Looks like it will take a while. Restarted Emby before I started refresh so I have a clean log. Will post log when done.
dcol 177 Posted June 9, 2019 Author Posted June 9, 2019 (edited) Refresh ended. I now have all the scheduled items in the guide and the art is now showing. I can also schedule new recordings now. The only issue that is left for me are the labels/tags not showing up in the guide. The refresh was set to update every 24 hours, so not sure what happened there Still not working right. Went back into guide and the recording I just setup is not showing up, but the others from the refresh are. I guess the guide does not get updated until the refresh occurs. NPVR does have the show set to record. Just doesn't show up in Emby. Edited June 9, 2019 by dcol
emveepee 133 Posted June 9, 2019 Posted June 9, 2019 (edited) Make sure you schedule the 24 hr task to start after the NextPVR EPG update. Loading recordings is also a task Refresh Internet Streams, not sure if this applies to your timers but it certainly is not a great change. Martin Edited June 9, 2019 by emveepee
