Sammy 791 Posted April 24, 2019 Author Posted April 24, 2019 Changing the format to what specifically? Are you referring to HLS (Streaming SRT subtitles). What is preventing it from seeking initially?I believe it's swapping containers from ts to mkv. Sent from my SM-G960U1 using Tapatalk
Sammy 791 Posted April 24, 2019 Author Posted April 24, 2019 I lot of this is CPU resource dependent on the server. For example if you happen to run MCEBuddy which is CPU intensive when scanning, cutting or converting files or have other files in Emby that are transcoding then it affects the speed of loading channels when these channels also need to run through ffmpeg to remux. This is why I schedule MCEBuddy to run at non-peak times. When I see long load time starting LiveTV I usually get out my phone and load jump desktop to go see what other processes may be running and see if I can kill them safely. Sent from my SM-G960U1 using Tapatalk
