halvdan 4 Posted March 2, 2019 Posted March 2, 2019 I'm running emby on 218+ with Linksys ea8500. emby worked great out of the box when playing locally, however when I looked into remote access, I ran into problems. I could not access the server remotely, so obviously like recommended, I had to port forward. I have done that before so I'm familiar with it. So I open the port in the router and remote access works. However, local playback is now crippled. It constantly buffers or won't play at all. If I remove the port forwarding in the router, local playback works again. I have tried port forwarding the default 8096 port and also other different port numbers. Same result. Local playback is crippled. Does anyone know what problem could be? To me this looks to be some kind of port conflict. Local vs remote.. I don't know. Thanks
CChris 59 Posted March 3, 2019 Posted March 3, 2019 Hi,I'm forwarding port 443 and port 80 to my synology.There, I have setup a reverse proxy and a virtual host. the virtual host is listening to port 80 and redirecting / rewriting to https (443).Then, the reverse proxy will do the rest and forwargind locally to emby on port 8096it looks like this for my setup:Portforwarding on the Router:Reverse Proxy Settings in Synology:Webstation Virutal Host settings..htaccess file in the virtual hostThis setup works perfectly fine for me.It allows me, that I can connect emby only through https - with a let's encrypt certificate even if I try to connect with http - it will switch to https.I haven't noticed any issues / diiferences between remote connection and local connection.
Luke 42242 Posted March 4, 2019 Posted March 4, 2019 @@halvdan please let us know if this helps. Thanks CCHris !
halvdan 4 Posted March 4, 2019 Author Posted March 4, 2019 Thanks CChris This seems a bit too advanced for my skill level.. but I'll give it a try
