Guest Posted March 2, 2019 Posted March 2, 2019 I tried to set up apache as reverse proxy for my emby server. Web app works fine. But I can't connect with an Emby app (e. g. Kodi) and I get 404 on every /embywebsocket request. Should be 101 I think. I have running nextcloud on the same apache and try to use 8443 for Emby. Any help appreciated. <VirtualHost *:80> ServerName toothless.goip.de RewriteEngine on RewriteCond %{REQUEST_SCHEME} =http RewriteRule ^/?(.*)$ https://toothless.goip.de/$1 [R=301,L] RewriteCond %{REQUEST_SCHEME} =ws RewriteRule ^/?(.*)$ wss://toothless.goip.de:8443/$1 [R=301,L] ErrorLog ${APACHE_LOG_DIR}/error.log CustomLog ${APACHE_LOG_DIR}/access.log combined </VirtualHost> SSLStaplingCache shmcb:${APACHE_RUN_DIR}/ssl_stapling_cache(129600) ServerName toothless.goip.de <VirtualHost *:443> Protocols h2 http/1.1 DocumentRoot /var/www/nextcloud ErrorLog ${APACHE_LOG_DIR}/error.log CustomLog ${APACHE_LOG_DIR}/access.log combined <FilesMatch \.php$> SetHandler proxy:unix:/run/php/php7.2-fpm.sock|fcgi://localhost/ </FilesMatch> SSLEngine on SSLUseStapling on SSLCertificateFile /etc/letsencrypt/live/toothless.goip.de/fullchain.pem SSLCertificateKeyFile /etc/letsencrypt/live/toothless.goip.de/privkey.pem Include /etc/letsencrypt/mod_options-ssl-apache.conf Header set Strict-Transport-Security "max-age=31556926; includeSubDomains; preload" <Directory /var/www/nextcloud> Options +FollowSymlinks AllowOverride All </Directory> </VirtualHost> <VirtualHost *:8443> Protocols h2 http/1.1 ErrorLog ${APACHE_LOG_DIR}/error.log CustomLog ${APACHE_LOG_DIR}/access.log combined SSLEngine on SSLUseStapling on SSLCertificateFile /etc/letsencrypt/live/toothless.goip.de/fullchain.pem SSLCertificateKeyFile /etc/letsencrypt/live/toothless.goip.de/privkey.pem Include /etc/letsencrypt/mod_options-ssl-apache.conf ProxyPass / http://localhost:8096/ ProxyPassReverse / http://localhost:8096/ ProxyPass /embywebsocket ws://localhost:8096/embywebsocket ProxyPassReverse /embywebsocket ws://localhost:8096/embywebsocket Header set Connection "Upgrade" Header set Upgrade "websocket" RequestHeader setifempty Connection "Upgrade" RequestHeader setifempty Upgrade "websocket" </VirtualHost>
Luke 42246 Posted March 3, 2019 Posted March 3, 2019 @@pir8radio how does this compare to your setup?
pir8radio 1313 Posted March 3, 2019 Posted March 3, 2019 I tried to set up apache as reverse proxy for my emby server. Web app works fine. But I can't connect with an Emby app (e. g. Kodi) and I get 404 on every /embywebsocket request. Should be 101 I think. I have running nextcloud on the same apache and try to use 8443 for Emby. Any help appreciated. Check out this post, make sure its not the same issue first: https://emby.media/community/index.php?/topic/64083-could-not-find-handler-for-embywebsocket/?p=636078
Guest Posted March 3, 2019 Posted March 3, 2019 (edited) This is one of several threads i've read before posting. Can't get this work using "ProxyPass" with proxy_wstunnel. Instead of that I used mod_rewrite for proxying the websocket traffic. After that worked I added some secure headers. <VirtualHost *:8443> Protocols h2 http/1.1 ErrorLog ${APACHE_LOG_DIR}/error.log CustomLog ${APACHE_LOG_DIR}/access.log combined SSLEngine on SSLUseStapling on SSLCertificateFile /etc/letsencrypt/live/toothless.goip.de/fullchain.pem SSLCertificateKeyFile /etc/letsencrypt/live/toothless.goip.de/privkey.pem Include /etc/letsencrypt/mod_options-ssl-apache.conf ProxyPass / http://localhost:8096/ ProxyPassReverse / http://localhost:8096/ RewriteEngine On RewriteCond %{HTTP:Connection} Upgrade [NC] RewriteCond %{HTTP:Upgrade} websocket [NC] RewriteRule ^/?(.*)$ ws://localhost:8096/$1 [P,L] Header unset Server Header set Strict-Transport-Security "max-age=31556926; includeSubDomains; preload" Header set Referrer-Policy "strict-origin" Header set X-Frame-Options "sameorigin" Header set X-XSS-Protection "1; mode=block" Header set X-Content-Type-Options "nosniff" Header set Content-Security-Policy "default-src 'none'; child-src 'self'; font-src 'self' data:; connect-src 'self' wss: ws: https://mb3admin.com https://github.com/MediaBrowser/; media-src 'self' blob: data: https://github.com/MediaBrowser/; manifest-src 'self'; base-uri 'none'; form-action 'self'; frame-ancestors 'self'; object-src 'none'; worker-src 'self' blob:; script-src 'self' https://www.gstatic.com; img-src data: https: http: ; style-src 'unsafe-inline' 'self' https://fonts.googleapis.com/css" </VirtualHost> Edited March 20, 2019 by loeffelpan
castillo92 1 Posted March 29, 2020 Posted March 29, 2020 (edited) This is one of several threads i've read before posting. Can't get this work using "ProxyPass" with proxy_wstunnel. Instead of that I used mod_rewrite for proxying the websocket traffic. After that worked I added some secure headers. [...] RewriteEngine On RewriteCond %{HTTP:Connection} Upgrade [NC] RewriteCond %{HTTP:Upgrade} websocket [NC] RewriteRule ^/?(.*)$ ws://localhost:8096/$1 [P,L] [...] Thats work for me too!! Thanks you very much!! I read severals post but the solution is yours: My vhost finally looks like: <VirtualHost *:443> ServerName my_server.com ServerAdmin webmaster@[member="Localhost"] DocumentRoot /var/www # La etiqueta env=!dontlog es una variable para que no se registren esos accesos: SetEnvIf Request_URI "^/emby/videos/*" dontlog SetEnvIf Request_URI "^/emby/Sessions/*" dontlog ErrorLog ${APACHE_LOG_DIR}/error.log CustomLog ${APACHE_LOG_DIR}/access.log combined env=!dontlog # Media Server Emby RewriteEngine On RewriteCond %{HTTP:Connection} Upgrade [NC] RewriteCond %{HTTP:Upgrade} websocket [NC] RewriteRule ^/?(.*)$ ws://localhost:8096/$1 [P,L] ProxyPass /emby/ http://192.168.1.50:8096/ ProxyPassReverse /emby/ http://192.168.1.50:8096/ Redirect permanent /emby /emby/ <IfModule mod_headers.c> Header always set Strict-Transport-Security "max-age=15768000; includeSubDomains; preload" </IfModule> SSLCertificateFile /etc/letsencrypt/live/my_server.com/fullchain.pem SSLCertificateKeyFile /etc/letsencrypt/live/my_server.com/privkey.pem Include /etc/letsencrypt/options-ssl-apache.conf </VirtualHost> Could you explain me why you added some secure headers? Emby does not have integrated? Edited March 29, 2020 by castillo92
