MPEG2 transcoding instead of direct play (AVCHD is OK)
Go to solution Solved by unisoft,
Starlionblue
Sure. Here you go. The avi is the original file and the mkv the one remuxed with MKVToolUI.
(Sorry about the messy formatting.)
Video
TitleSD MPEG4
CodecMPEG4
Codec tagXVID
ProfileAdvanced Simple Profile
Level5
Resolution576x432
Aspect ratio4:3
AnamorphicNo
InterlacedNo
Framerate29.97
Bitrate1,071 kbps
Pixel formatyuv420p
Ref frames1
Audio
TitleMP3 stereo (Default)
CodecMP3
Layoutstereo
Channels2 ch
Bitrate128 kbps
Sample rate48,000 Hz
DefaultYes
Subtitle
TitleEnglish (SRT)
LanguageEnglish
CodecSRT
DefaultNo
ForcedNo
ExternalYes
Containermkv
Path/share/Stuff/Movies/PG - Series/Star Trek - The Next Generation/Season 7/Star Trek The Next Generation - 7x01 - Descent (2).mkv
Size346 MB
Video
TitleSD MPEG4
CodecMPEG4
Codec tagXVID
Level5
Resolution576x432
Aspect ratio4:3
AnamorphicNo
InterlacedNo
Framerate29.97
Bitrate942 kbps
Pixel formatyuv420p
Ref frames1
Audio
TitleMP3 stereo
CodecMP3
Layoutstereo
Channels2 ch
Bitrate126 kbps
DefaultNo
Subtitle
TitleEnglish (SRT)
LanguageEnglish
CodecSRT
DefaultNo
ForcedNo
ExternalYes
Containeravi
Path/share/Stuff/Movies/PG - Series/Star Trek - The Next Generation/Season 7/Star Trek The Next Generation - 7x01 - Descent (2).avi
Size350 MB
Edited by Starlionblue
Starlionblue
I tried remuxing with ffmpeg. Same result.
I used MediaInfo to extract the file data. See below.
Original file:
General
Complete name                            : S:\Movies\PG - Series\Star Trek - The Next Generation\Season 7\Star Trek  The Next Generation - 7x01 - Descent (2).avi
Format                                   : AVI
Format/Info                              : Audio Video Interleave
File size                                : 350 MiB
Duration                                 : 45 min 10 s
Overall bit rate mode                    : Variable
Overall bit rate                         : 1 083 kb/s
Writing application                      : Nandub v1.0rc2
Writing library                          : Nandub build 1852/release
Video
Format                                   : MPEG-4 Visual
Format profile                           : Advanced Simple@L5
Format settings                          : BVOP2 / GMC3 / QPel / Custom Matrix
Format settings, BVOP                    : 2
Format settings, QPel                    : Yes
Format settings, GMC                     : 3 warppoints
Format settings, Matrix                  : Custom
Muxing mode                              : Packed bitstream
Codec ID                                 : XVID
Codec ID/Hint                            : XviD
Bit rate                                 : 943 kb/s
Width                                    : 576 pixels
Height                                   : 432 pixels
Display aspect ratio                     : 4:3
Frame rate                               : 29.970 (30000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Compression mode                         : Lossy
Bits/(Pixel*Frame)                       : 0.126
Stream size                              : 305 MiB (87%)
Writing library                          : XviD 1.0.0 Beta2.5 (UTC 2003-12-18)
Audio
Format                                   : MPEG Audio
Format version                           : Version 1
Format profile                           : Layer 3
Format settings                          : Joint stereo / MS Stereo
Codec ID                                 : 55
Codec ID/Hint                            : MP3
Bit rate mode                            : Variable
Bit rate                                 : 128 kb/s
Channel(s)                               : 2 channels
Sampling rate                            : 48.0 kHz
Frame rate                               : 41.667 FPS (1152 SPF)
Stream size                              : 40.9 MiB (12%)
Alignment                                : Aligned on interleaves
Interleave, duration                     : 24  ms (0.72 video frame)
Interleave, preload duration             : 139  ms
Writing library                          : LAME3.93a
Encoding settings                        : -m j -V 4 -q 2 -lowpass 17.5 --abr 128
Remuxed file:
General
Unique ID                                : 153227599667021814094348475226930640477 (0x73468FEFA695341D2813113926B1765D)
Complete name                            : S:\Movies\PG - Series\Star Trek - The Next Generation\Season 7\Star Trek  The Next Generation - 7x01 - Descent (2).mkv
Format                                   : Matroska
Format version                           : Version 4
File size                                : 347 MiB
Overall bit rate                         : 1 074 kb/s
Writing application                      : Lavf58.27.103
Writing library                          : Lavf58.27.103
ErrorDetectionType                       : Per level 1
Video
Codec ID                                 : V_MPEG4/ISO/ASP
Codec ID/Info                            : Advanced Simple Profile
Bit rate                                 : 924 kb/s
Width                                    : 576 pixels
Height                                   : 432 pixels
Frame rate mode                          : Constant
Frame rate                               : 29.970 (29970/1000) FPS
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.124
Stream size                              : 299 MiB (86%)
Default                                  : Yes
Forced                                   : No
Audio
Format                                   : MPEG Audio
Codec ID                                 : A_MPEG/L3
Codec ID/Hint                            : MP3
Bit rate                                 : 128 kb/s
Delay relative to video                  : -33 ms
Default                                  : Yes
Forced                                   : No
Starlionblue
Tried remuxing the same file with the Emby Server conversion feature and it works fine. Emby wins!  :D
The myFFmpeg UI app for FFmpeg also works, but it costs €20, and FFmpeg manages to hard crash/reboot my desktop at random times. So....
