jsc1205 51 Posted March 1, 2019 Posted March 1, 2019 Noticed that when playing around in Emby that after I start a movie, I'm not able to skip chapters. It just jumps ahead a few seconds but that's all. I'm using a Harmony Elite remote and even if I do a long press same thing happens. Also noticed if i start a movie and stop it at some point, it's not letting me resume at the stopping point but rather start from the beginning. Thanks for the help
Luke 42246 Posted March 1, 2019 Posted March 1, 2019 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. thanks !
CBers 7554 Posted March 1, 2019 Posted March 1, 2019 Noticed that when playing around in Emby that after I start a movie, I'm not able to skip chapters. It just jumps ahead a few seconds but that's all. I'm using a Harmony Elite remote and even if I do a long press same thing happens. Also noticed if i start a movie and stop it at some point, it's not letting me resume at the stopping point but rather start from the beginning. Thanks for the help Does it work OK using the Shield remote or controller? Perhaps the mappings on your Harmony are not 100% correct?
jsc1205 51 Posted March 1, 2019 Author Posted March 1, 2019 I don't think its the mapping on the harmony remote because it works perfectly fine in with all the other apps such as plex or kodi
CBers 7554 Posted March 1, 2019 Posted March 1, 2019 I don't think its the mapping on the harmony remote because it works perfectly fine in with all the other apps such as plex or kodi Does it work OK using the Shield remote or controller?
