contenitore21 2 Posted July 27, 2019 Author Posted July 27, 2019 well. next week maybe i can try. Thx
contenitore21 2 Posted July 27, 2019 Author Posted July 27, 2019 This is done nowCould you repeat from where have i to download? Or where CAn i read instructions, i don't remember. Thx Inviato dal mio LEX720 utilizzando Tapatalk
Luke 42242 Posted July 27, 2019 Posted July 27, 2019 Could you repeat from where have i to download? Or where CAn i read instructions, i don't remember. Thx Inviato dal mio LEX720 utilizzando Tapatalk Installations on how to install the app can be found on our website: https://emby.media/download.html Thanks.
FrostByte 5453 Posted July 27, 2019 Posted July 27, 2019 The IP is still hosting 2.2.4, so if you want 2.2.6 you will need to get the file from GitHub and follow those instructions
FrostByte 5453 Posted July 29, 2019 Posted July 29, 2019 @contenitore21 IP 173.230.139.54 is now updated with 2.2.6 if you haven't updated yet. I successfully tested SamES fix and movie genres are now working for me with no 500 error code
contenitore21 2 Posted July 30, 2019 Author Posted July 30, 2019 @contenitore21 IP 173.230.139.54 is now updated with 2.2.6 if you haven't updated yet. I successfully tested SamES fix and movie genres are now working for me with no 500 error code so i've to type 2.2.4 , 2.2.6 or 173.xxxxx? sorry, i don't understane
FrostByte 5453 Posted July 30, 2019 Posted July 30, 2019 The latest version of the app is 2.2.6 and was just updated on server with IP 173.230.139.54 yesterday so you don't need to get it from GitHub first and follow those added instructions any more. The instructions in the pinned thread should be good. Use the 2nd post for H-series and the 4th one for E-series, etc https://emby.media/community/index.php?/topic/9869-samsung-smart-tv-2011-2014-third-party-orsay-app-install-instructions/&do=findComment&comment=277344 1
contenitore21 2 Posted July 30, 2019 Author Posted July 30, 2019 Sorry i misundetstood server and version.... Inviato dal mio LEX720 utilizzando Tapatalk
contenitore21 2 Posted July 30, 2019 Author Posted July 30, 2019 all ok. Thx. Now i can classify my videos by genre and than search it.There is anyway to do the same thing by tag? I can insert tags but i don't see tags search features. Thx to all
