contenitore21 2 Posted May 28, 2019 Author Posted May 28, 2019 I still have some difficulties in getting into the raspberry for the emby log, I'm working on it, have patience. On the TV app I don't see the settings entry. thx
FrostByte 5453 Posted May 28, 2019 Posted May 28, 2019 I still have some difficulties in getting into the raspberry for the emby log, I'm working on it, have patience. On the TV app I don't see the settings entry. thx On the TV go to Settings in the menu Across the top you should see several Settings areas including the word Log Scroll to the top and then over to the right and click on the word Log Once in the Log you should be able to scroll up and down, but you should see the 500 error toward the bottom if you went right to the log after the error occurred 1
FrostByte 5453 Posted May 28, 2019 Posted May 28, 2019 What type of machine is the server on? You should be able to use any web browser to open the logs
Luke 42241 Posted May 28, 2019 Posted May 28, 2019 Yes that's correct. How to report a problem. Thanks.
contenitore21 2 Posted May 28, 2019 Author Posted May 28, 2019 On the TV go to Settings in the menu Finally i've found settings I attach log and screen of selection THX
contenitore21 2 Posted May 28, 2019 Author Posted May 28, 2019 What type of machine is the server on? You should be able to use any web browser to open the logs it's a raspberry, but a friend of mine has installed it and I can't get to the server on the PC, but only on the contents. I await his help.
contenitore21 2 Posted May 28, 2019 Author Posted May 28, 2019 Yes that's correct. How to report a problem. Thanks. Yes, I will do it as soon i access to server log. Thanks
FrostByte 5453 Posted May 28, 2019 Posted May 28, 2019 (edited) I'm posting my server log since I see the same error you have in your pics. App v2.2.4a Server 4.3.0.5 beta TV Samsung 2013 F8000 with 2014 Evolution Kit Steps: Start app Click Movies Scroll up and over and click Genres Same 500 error as contenitore21 pics above https://pastebin.com/Bz0V8nsV Edited May 28, 2019 by FrostByte 1
Luke 42241 Posted May 28, 2019 Posted May 28, 2019 I'm posting my server log since I see the same error you have in your pics. App v2.2.4a Server 4.3.0.5 beta TV Samsung 2013 F8000 with 2014 Evolution Kit Steps: Start app Click Movies Scroll up and over and click Genres Same 500 error as contenitore21 pics above https://pastebin.com/Bz0V8nsV I would re-evaluate when you have a newer beta. thanks. 2
FrostByte 5453 Posted May 28, 2019 Posted May 28, 2019 Okay. Will do. I'm waiting on solabc16 to upload a new beta to Package Center. I know I'm way behind.
contenitore21 2 Posted May 28, 2019 Author Posted May 28, 2019 THX to all Inviato dal mio LEX720 utilizzando Tapatalk
contenitore21 2 Posted May 30, 2019 Author Posted May 30, 2019 Yes, I will do it as soon i access to server log. Thanks I'm sorry but i can't get the log and my friend too. I've installed emby server on a raspberry pi3 dietpi and i don't know how to get log: maybe you have any suggestion? Otherwise no matter, i'll wait for new app (so i've understood, is it right?) thx
Luke 42241 Posted May 30, 2019 Posted May 30, 2019 The instructions for log files are in the link I provided earlier.
contenitore21 2 Posted May 31, 2019 Author Posted May 31, 2019 ok, maybe i've activated log, then i've got return code 500 and there is the log file. I hope it's good for you. Let me know. THX Log.txt 1
contenitore21 2 Posted May 31, 2019 Author Posted May 31, 2019 I'll be out in the next 3 days, maybe I'll be able to read you but I won't be able to work on emby. Thanks for your attention
FrostByte 5453 Posted May 31, 2019 Posted May 31, 2019 I get the same 500 error when clicking genres which should have been captured in my log from earlier.
Luke 42241 Posted May 31, 2019 Posted May 31, 2019 It's due to the ItemCounts field being requested. @@SamES can that be removed? thanks. 1
SamES 1084 Posted June 2, 2019 Posted June 2, 2019 It's due to the ItemCounts field being requested. @@SamES can that be removed? thanks. Will do, thanks
contenitore21 2 Posted June 5, 2019 Author Posted June 5, 2019 Will do, thanks will be notified on the forum when I can redo the test? thanks
contenitore21 2 Posted June 11, 2019 Author Posted June 11, 2019 there is any news about 500 response code? THX
