pixsoul 1 Posted May 7, 2014 Posted May 7, 2014 Hi All, On the old Media Browser for WMC I used to be able to skip to the next episode of the series when viewing an episode in TV shows by using the next track button. I thought this might have been a native WMC thing, but obviously it must be part of the MB plugin as its not working in MB3. Is there another way to skip to the next episode in MB3C or is this feature still in dev? Cheers, Ken
ebr 16334 Posted May 7, 2014 Posted May 7, 2014 Depends on the theme but in chocolate you can use the paging keys or channel up and down.
pixsoul 1 Posted May 8, 2014 Author Posted May 8, 2014 Depends on the theme but in chocolate you can use the paging keys or channel up and down. Thanks EBR, I'm using Chocolate; I'll give that a go.
