martincom 29 Posted February 27, 2019 Posted February 27, 2019 I'm thinking this is a Roku issue. However, if someone has the same Roku and a different channel with multiple audio tracks, could you test and report your findings? Below is the post I submitted to the Roku forum: When streaming a movie, from our Emby media server, that has multiple audio tracks, those tracks are displayed on the Roku Ultra audio sub-menu, within the Options menu. The audio menu GUI does change states and reports the change in track selection. However, actual playback audio does not change and remains fixed at the first audio track. When changing audio track selections, the playback audio does momentarily dropout with the change in selection, indicating at least something is trying to initiate the change.If I edit the movie playback file (within the Emby media server), utilizing the Handbrake application, and move up an audio track to the first selection, that is the track that is locked into playback on the Roku Ultra.I do not have another "channel" that has multiple audio tracks, so I have not been able test and verify this issue on another channel. However, the symptoms point toward this being a Roku Ultra issue.Model: 4660RW - Roku UltraS/N: YJ006N394217Software: 9.0.0 - Build 4142-6Network Connection: Hardwire ethernet port
Luke 42242 Posted February 28, 2019 Posted February 28, 2019 Hi there, can we look at an example? Please attach the information requested in how to report a media playback issue. thanks !
speechles 2062 Posted February 28, 2019 Posted February 28, 2019 (edited) I assume you are using the * button when you mention "Options" menu. You are doing this as the video is playing too. Instead of this, simply press down on your d-pad to bring up the on-screen display (OSD). At the very bottom of the OSD are a row of icons under the transport controls. One of these icons will look like a speaker with sound waves coming out. Click that and choose your audio stream. This will work. The Roku options menu using * will only show options that are available in direct play. If you were transcoding it will limit you on audio stream/subtitle choices. To always have the best experience with the full choices available you must always press down and use the OSD. Remember not to use * and the Roku options menu. Edited February 28, 2019 by speechles
martincom 29 Posted March 1, 2019 Author Posted March 1, 2019 Speechless, You're my new best friend! You hit the nail squarely on the head. Not only was that the issue with selecting audio tracks, but sub-titles as well. I had about 50 movies that were continuously displaying sub-titles and the "*' option menu had no effect upon them. I was beginning to think I mistakenly hit a key or loaded the wrong preset, when I was muxing them, and had set the subtitle to burn in. I'm knew to streaming and Roku. I don't recall any mention of the screen bottom OSD menu in the online instructions. The 4660 Ultra doesn't have a d-pad, but I figured it was there somewhere. It is the down arrow on the 4660. Also, these were all direct play. The "*" menu did appear and accept the command, but nothing changed. Everything works as it should from OSD menu along the bottom of the screen.
speechles 2062 Posted March 1, 2019 Posted March 1, 2019 https://sdkdocs.roku.com/display/sdkdoc/Remote+Control+Buttons The dpad on the Roku remote. The digital/directional pad. The above URL explains most of the functions that developers must allow Roku to handle and which the app can. That can act as a guide to why things must be the way they are.
