johnny_swindle 5 Posted February 27, 2019 Posted February 27, 2019 I am thinking about upgrading all my Kodi boxes to 18.1. Will this upgrade impact Emby for Kodi 4.05 or will an upgrade to Emby for Kodi be necessary as part of the Kodi upgrade. Thanks...
Angelblue05 4132 Posted February 27, 2019 Posted February 27, 2019 You will need to reset your local database. The path system has been changed between Krypton and Leia. Does this help?
johnny_swindle 5 Posted February 28, 2019 Author Posted February 28, 2019 Thank you @@Angelblue05 It does....is the correct sequence: Upgrade to Kodi 18.1 allowing it to upgrade the database, etc Go into Emby for Kodi on the newly upgraded Kodi box and reset database(s) and allow scans to take place Seems too straight forward.....did I miss something? Johnny You will need to reset your local database. The path system has been changed between Krypton and Leia.Does this help? 1
Solution Angelblue05 4132 Posted February 28, 2019 Solution Posted February 28, 2019 That is correct. Upgrade Kodi first, then reset. 1
alext41 4 Posted March 1, 2019 Posted March 1, 2019 One question to this, do i need also to reset the db when upgrading from Kodi 18 to Kodi 18.1?
Angelblue05 4132 Posted March 1, 2019 Posted March 1, 2019 One question to this, do i need also to reset the db when upgrading from Kodi 18 to Kodi 18.1? No. 1
