Luke 42210 Posted June 7, 2020 Posted June 7, 2020 Can you please update to 4.4.3 and then run a library scan? Thanks.
khenghis 2 Posted June 7, 2020 Posted June 7, 2020 Correct me if I'm wrong, I dont believe it exist yet on FreeNas. I tried to run an update but it failed resulting no update available.
Luke 42210 Posted June 8, 2020 Posted June 8, 2020 Correct me if I'm wrong, I dont believe it exist yet on FreeNas. I tried to run an update but it failed resulting no update available. How did you install emby server?
khenghis 2 Posted June 9, 2020 Posted June 9, 2020 From my Freenas Dashbord plugins section. However threw Emby directly it is stating : Version 4.4.2.0 checkEmby Server is up to date And if I'm trying to run the update threw my Freenas it result with the error no update. However I clearly know its outdate since my Windows Emby server states : Version 4.4.3.0 checkEmby Server is up to date That is why I was wondering if the update wasnt just out yet on Freenas or the issue actually come from my server.
Luke 42210 Posted June 9, 2020 Posted June 9, 2020 Right ok, it's probably just not released yet in the freenas plugin system.
Villiam 0 Posted July 26, 2020 Posted July 26, 2020 On 3/1/2019 at 3:23 PM, Happy2Play said: The trailer must be the exact name of the movie file with "-trailer". So moviename - 1080p.ext and moviename-trailer.ext will not work. It must be moviename - 1080p.ext and moviename - 1080p-trailer.ext. (file extensions don't matter) What about trailers kept in a trailer subfolder within each movie folder? On 3/4/2019 at 11:11 AM, serpi said: Of course, you could put the trailers into a subdir named trailers inside the movie folder, then it doesn't matter, how they are named. That's the way I'm doing it... Ciao, Alfred That's how I had been doing it for over a decade, but apparently that's not working now either. Is it still working for you or do?
serpi 82 Posted July 27, 2020 Posted July 27, 2020 21 hours ago, Villiam said: That's how I had been doing it for over a decade, but apparently that's not working now either. Is it still working for you or do? That's still working for me (Emby Server 4.4.3.0 on Windows). Every movie/series has it own folder and there's a folder trailers with the trailer file in it. Also, I'm not using mixed content, only seperated movie/series libraries. Ciao, Alfreds
