Noddyliten 2 Posted February 26, 2019 Posted February 26, 2019 Just a question around functionality. After converting a movie to mobile format and 4Mbs pr second I have to click on the film and then there is a dropdown box where I can choose which format to play. However, this does not happend every time. Sometimes the library gets updated with a new version of the film displaying 2 posters of the film. One with the origional format and the other with the converted format. I would like only one poster and the to choose the format to play. I'm doing the exact same thing to convert the movies to a smaller format. The converted files get a "- movies.mp4" extension and are stored in the same folder as the original file. Is this a bug?
ebr 16313 Posted February 26, 2019 Posted February 26, 2019 Hi. If you follow the naming conventions for multiple versions, then it will show up as you desire.
Noddyliten 2 Posted February 26, 2019 Author Posted February 26, 2019 Strange, is not the attached naming convention correct? This move is shown as two posters.
Happy2Play 9806 Posted February 26, 2019 Posted February 26, 2019 Strange, is not the attached naming convention correct? This move is shown as two posters. No as those are two separate movie folders. \Bad Times at the El Royale (2018)\ \Bad Times at the El Royale (2018) - 720p\ You can use the multi-select tool and manually group them if you like. Not sure what is happening in you first post.
ebr 16313 Posted February 27, 2019 Posted February 27, 2019 Strange, is not the attached naming convention correct? This move is shown as two posters. You need to follow the naming conventions for the FILES, not the folders. As indicated in that doc - the files must start with the same name as the folder and be in that folder.
Noddyliten 2 Posted February 27, 2019 Author Posted February 27, 2019 Thanx, was not aware of this functionality, excellent:) 1
