Duffyx 25 Posted February 26, 2019 Posted February 26, 2019 (edited) Hi guys, I'm currently figuring out how I can enable ffmpeg to use my /dev/dri/renderD128 device which is the iGPU of my intel chip. Currently I have the following things covered: - drm module is loaded and /dev/dri/renderD128 is accessible in jail - emby user has access to the device node - I have installed libva-intel-driver and it is picked up by vainfo - ffmpeg is compiled with libva support I'm sure that emby can access the node and use it with the ffmpeg supplied by emby. As show in the following command output: root@emby:/usr/local/lib/emby-server/bin # su -m emby -c "./ffmpeg -vaapi_device /dev/dri/renderD128" ffmpeg version 4.0.2-emby_p_2018_12_01 Copyright © 2000-2018 the FFmpeg developers built with FreeBSD clang version 6.0.1 (tags/RELEASE_601/final 335540) (based on LLVM 6.0.1) configuration: --cc=cc --disable-autodetect --disable-doc --disable-ffplay --disable-shared --enable-fontconfig --enable-gmp --enable-gnutls --enable-gpl --enable-iconv --enable-libass --enable-libdrm --enable-libfreetype --enable-libfribidi --enable-libopus --enable-libtheora --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libx265 --enable-libzvbi --enable-static --enable-vaapi --enable-version3 --enable-libmp3lame --disable-libsmbclient libavutil 56. 14.100 / 56. 14.100 libavcodec 58. 18.100 / 58. 18.100 libavformat 58. 12.100 / 58. 12.100 libavdevice 58. 3.100 / 58. 3.100 libavfilter 7. 16.100 / 7. 16.100 libswscale 5. 1.100 / 5. 1.100 libswresample 3. 1.100 / 3. 1.100 libpostproc 55. 1.100 / 55. 1.100 Hyper fast Audio and Video encoder usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}... Use -h to get full help or, even better, run 'man ffmpeg' Even if I supply an input file and output file for the sake of example it starts transcoding just fine on hardware. root@emby:/tmp # su -m emby -c "/usr/local/lib/emby-server/bin/ffmpeg -vaapi_device /dev/dri/renderD128 -i /media/movies/Avatar\ \(2009\)/Avatar\ \(2009\).mp4 test.mp4" Chapter #0:72: start 10688.469000, end 10689.481000 Metadata: title : Chapter 72 Stream #0:0(eng): Video: h264 (libx264) (avc1 / 0x31637661), yuv420p(progressive), 1920x1080 [sAR 1:1 DAR 16:9], q=-1--1, 23.98 fps, 24k tbn, 23.98 tbc (default) Metadata: creation_time : 2013-04-18T10:50:46.000000Z encoder : Lavc58.18.100 libx264 Side data: cpb: bitrate max/min/avg: 0/0/0 buffer size: 0 vbv_delay: -1 Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 128 kb/s (default) Metadata: creation_time : 2013-04-18T10:53:43.000000Z encoder : Lavc58.18.100 aac frame= 1124 fps= 54 q=28.0 size= 12290kB time=00:00:47.29 bitrate=2128.7kbits/s dup=1 drop=0 speed=2.28x This indicates to me that the user emby is able to use /dev/dri/renderD128 and should be able to use the device node and hardware. In the web interface under transcoding I see nothing popping up as possible hardware accelerators as show in picture. I have attached my hardware detection log and my most recent server log where the server starts up and does some hardware detection stuffs. This is my output from vainfo: vainfo: VA-API version: 1.4 (libva 2.4.0) vainfo: Driver version: Intel i965 driver for Intel® Skylake - 2.3.0 vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Simple : VAEntrypointEncSlice VAProfileMPEG2Main : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointEncSlice VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP VAProfileH264ConstrainedBaseline: VAEntrypointFEI VAProfileH264ConstrainedBaseline: VAEntrypointStats VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264Main : VAEntrypointEncSliceLP VAProfileH264Main : VAEntrypointFEI VAProfileH264Main : VAEntrypointStats VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileH264High : VAEntrypointEncSliceLP VAProfileH264High : VAEntrypointFEI VAProfileH264High : VAEntrypointStats VAProfileH264MultiviewHigh : VAEntrypointVLD VAProfileH264MultiviewHigh : VAEntrypointEncSlice VAProfileH264StereoHigh : VAEntrypointVLD VAProfileH264StereoHigh : VAEntrypointEncSlice VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc VAProfileJPEGBaseline : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointEncPicture VAProfileVP8Version0_3 : VAEntrypointVLD VAProfileVP8Version0_3 : VAEntrypointEncSlice VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointEncSlice Log.txt Log.txt Edited February 27, 2019 by Duffyx 1
Luke 42234 Posted February 26, 2019 Posted February 26, 2019 Hi, did you install the server through freebsd ports?
Duffyx 25 Posted February 26, 2019 Author Posted February 26, 2019 (edited) I'm installing Emby 4.0.2.0 from ports by using my local patch against the ports tree (the one which is currently in review and soon to be committed for everyone to use; FYI) Edited February 26, 2019 by Duffyx
alucryd 318 Posted March 19, 2019 Posted March 19, 2019 (edited) Could you please try adding this to the emby-server service file? export LIBVA_DRIVERS_PATH=/usr/local/lib/dri Edited March 19, 2019 by alucryd
Duffyx 25 Posted March 19, 2019 Author Posted March 19, 2019 (edited) Any specific location in the service script I should put this? Will test later today. Edited March 19, 2019 by Duffyx
Duffyx 25 Posted March 19, 2019 Author Posted March 19, 2019 (edited) Hi, I just added the entry as such: . /etc/rc.subr name=emby_server rcvar=${name}_enable load_rc_config ${name} : ${emby_server_enable:="no"} : ${emby_server_user:="emby"} : ${emby_server_group:="emby"} : ${emby_server_data_dir:="/var/db/emby-server"} : ${emby_server_ffdetect:="/usr/local/lib/emby-server/bin/ffdetect"} : ${emby_server_ffmpeg:="/usr/local/lib/emby-server/bin/ffmpeg"} : ${emby_server_ffprobe:="/usr/local/lib/emby-server/bin/ffprobe"} export LIBVA_DRIVERS_PATH=/usr/local/lib/dri pidfile="/var/run/emby-server.pid" procname="/usr/local/bin/mono" command="/usr/sbin/daemon" command_args="-f -p ${pidfile} ${procname} /usr/local/lib/emby-server/system/EmbyServer.exe \ -os freebsd \ -ffdetect ${emby_server_ffdetect} \ -ffmpeg ${emby_server_ffmpeg} \ -ffprobe ${emby_server_ffprobe} \ -programdata ${emby_server_data_dir} \ -updatepackage emby-server-freebsd_{version}_amd64.txz" <snip> Although it did not help out, my hardware transcoding menu is still blank after restarting emby-server. Edited March 19, 2019 by Duffyx
alucryd 318 Posted March 30, 2019 Posted March 30, 2019 Thanks for the feedback. I'm trying sth with our ffdetect binary, it'll take a few hours to build, but I'd like you to try it out when it is done if that's okay with you. You won't need to export LIBVA_DRIVERS_PATH with this one.
alucryd 318 Posted March 31, 2019 Posted March 31, 2019 There you go: https://paste.xinu.at/XEifg/ Could you first try running the following with this binary and post the result here? ffdetect vaencdec If your vaapi devices are detected it should work within emby as well, you can then try replacing the ffdetect binary shipped with emby with this one.
Duffyx 25 Posted March 31, 2019 Author Posted March 31, 2019 Result of command: sudo ./ffdetect vaencdec ffdetect version 4.0.3-emby_2019_03_26 Copyright © 2018-2018 softworkz for Emby LLC built with gcc 8.3.0 (FreeBSD Ports Collection) configuration: --cc=gcc --arch=x86_64 --prefix=/usr/home/embybuilder/Buildbot/x64_freebsd/ffdetect-x64_freebsd/staging --pkg-config=pkg-config --disable-doc --disable-ffmpeg --disable-ffplay --disable-ffprobe --disable-vdpau --enable-vaapi --extra-libs='-ldrm -lva -lva-drm -ldl -lm -lpthread' --disable-shared --enable-static libavutil 56. 14.100 / 56. 14.100
Duffyx 25 Posted April 5, 2019 Author Posted April 5, 2019 (edited) Can someone provide a command that I can use to assure it is not a driver problem? E.G. that the device node at /dev/dri/renderD128 works as expected and it is in fact an Emby issue. I'm starting to think that might not be the case but at least if not we can rule it out. Edited April 5, 2019 by Duffyx
Duffyx 25 Posted April 11, 2019 Author Posted April 11, 2019 (edited) As some extra information for the devs, I'm not running any X11 server or Wayland on my server ("headless" with a screen of console output). Of course everything else is loaded, such as the iGPU drm module etc. Edited April 11, 2019 by Duffyx
alucryd 318 Posted April 17, 2019 Posted April 17, 2019 Can't passthrough my /dev/dri directory to KVM because freebsd doesn't support the 9p protocol so this is kinda hard to test, but it looks like a bug in our ffdetect, it should definitely be working when using system libva libraries. We will notify our dev to get some insight. 1
Luke 42234 Posted April 17, 2019 Posted April 17, 2019 You could try these two things: sys_analyzer_linux.zipThis is a graphics assessment tool from Intel ffdetect_linux_x64.zipAn ffdetect version with minimal dependencies. Should be run in a plain vanilla shell without any any modifications of environment variables etc. and from a directory that doesn't contain any other libraries (.so) or 'drivers'. ffdetect_linux_x64.zip sys_analyzer_linux.zip
Luke 42234 Posted May 9, 2019 Posted May 9, 2019 @@Duffyx can you please try this again as soon as our 4.1.1 release lands in freebsd ports? Thanks !
Duffyx 25 Posted May 31, 2019 Author Posted May 31, 2019 I just tried with Emby 4.1.1.0 but still ffdetect can't find my drm node for some reason while vainfo still reports everything being fine. 1
Luke 42234 Posted May 31, 2019 Posted May 31, 2019 Ok thanks for the info. We'll continue to investigate.
jinie 4 Posted June 2, 2019 Posted June 2, 2019 Just wanted to chime in with the same problem. I've been lurking in this thread since it was originally posted, and i've been silently trying to same suggestions without any luck. Just so the devs are aware that there are at least two FreeBSD users out there 1
Duffyx 25 Posted June 14, 2019 Author Posted June 14, 2019 Is this a relevant bug that could prevent Emby from detecting my hardware capabilities? https://bugs.freebsd.org/bugzilla/show_bug.cgi?id=236933
Luke 42234 Posted June 24, 2019 Posted June 24, 2019 We're still trying to chase this down. If you know someone knowledge about this in the freebsd community let them know we'll be happy to employ them temporarily to help us with it. Thanks.
Duffyx 25 Posted July 13, 2019 Author Posted July 13, 2019 (edited) I'm wondering if there is like a hidden option in the web interface that the user can enforce hardware transcoding. That option would just hard use the render node, instead of relying on the ffdetect to detect it. That way we could rule out that Emby *can/cannot* use a render node and it is a bug in the fftdetect binary. Edited July 13, 2019 by Duffyx
bizarro252 17 Posted August 21, 2019 Posted August 21, 2019 Bumping this to see if there is any news, as well as offer up myself as another tester.
