pcm2a 9 Posted February 26, 2019 Posted February 26, 2019 Synology DS216+, 8gb ram, internal 7200rpm drives. The playlist (m3u) and guide xml are both on the local file system. The guide is ~170 channels, 7 days of data and the xml file is around 20 mb. Refreshing the guide takes about an hour. The cpu remains about 5-15% at all times. Dell laptop, core i7, 4gb ram, internal 5400rpm drive. The same playlist and xml. Refreshing the guide takes 5-8 minutes. 2019-02-26 12:44:54.722 Info App: xmltv path: /volume1/storage/iptv/epgbeast.xml 2019-02-26 12:45:06.076 Info App: xmltv path: /volume1/storage/iptv/epgbeast.xml 2019-02-26 12:45:20.275 Info App: xmltv path: /volume1/storage/iptv/epgbeast.xml 2019-02-26 12:45:35.866 Info App: xmltv path: /volume1/storage/iptv/epgbeast.xml 2019-02-26 12:45:53.805 Info App: xmltv path: /volume1/storage/iptv/epgbeast.xml 2019-02-26 12:46:08.322 Info App: xmltv path: /volume1/storage/iptv/epgbeast.xml Any ideas why it is so slow on the Synology NAS?
Luke 42245 Posted February 26, 2019 Posted February 26, 2019 Hi, although one topic is about a url and the other is a file, my response is the same as your other topic about this: https://emby.media/community/index.php?/topic/70570-slow-guide-xmltv-import-when-using-a-url/&do=findComment&comment=707394 Thanks.
pcm2a 9 Posted February 26, 2019 Author Posted February 26, 2019 (edited) Are you saying that the linux Emby server that I'm using on a test dell laptop already has the improvements and that's why it only takes 5 minutes? Where the Synology Emby server is not optimized so it takes an hour. Edited February 26, 2019 by pcm2a
Luke 42245 Posted February 26, 2019 Posted February 26, 2019 No i'm saying that it's something we can improve in a future update. thanks.
pcm2a 9 Posted February 26, 2019 Author Posted February 26, 2019 Is there no way to determine what the bottleneck is in the Synology vs a laptop? Disk write speed, cpu power, etc.
Luke 42245 Posted February 26, 2019 Posted February 26, 2019 It is reading the data multiple times and once that is improved I don't think this will be much of an issue anymore. Thanks.
