jsc1205 51 Posted February 26, 2019 Posted February 26, 2019 Would like to know if there is any way to change the neon green colored highlighted cursor when moving around in Emby?? Also in TV Shows, is the a way to get rid of the number icon in the upper right of the poster image (total number of episodes)??
ebr 16337 Posted February 26, 2019 Posted February 26, 2019 Would like to know if there is any way to change the neon green colored highlighted cursor when moving around in Emby?? Hi. Not at this time although this should pretty much only be on buttons at this point (except in a season view). Also in TV Shows, is the a way to get rid of the number icon in the upper right of the poster image (total number of episodes)?? That is not the total number of episodes. It is the number of items you have not watched. This is displayed system-wide (all apps). There is not currently an option to turn this off but there may be in the future.
jsc1205 51 Posted February 26, 2019 Author Posted February 26, 2019 Thanks for the response. On the green highlight/curse, I'm asking if it can be changed because small areas it's not to bad. But when scrolling through TV show episodes and its huge the color id kind of overwhelming. A grayish color or something more subdued would look better instead of the green. As far as the number watched in TV shows it would definitely be good to be able to turn that off.
